Analyzers
5341 Discussions
Vtune assertion failed- Linux/chromeOS
Vaibhav_S_Intel
Vtune assertion failed during hotspot analysis on ChromeOS(ADL). Can you please check the attached logs and let me know the WA for this issue.
JaideepK_Intel
Can you try to run Vtune on a supporting operating system? Chrome OS is not mentioned in the Vtune system requirements.
Link: https://www.intel.com/content/www/us/en/developer/articles/system-requirements/vtune-profiler-system-requirements.html
From the crash report, I can see you are using an older version of Vtune, i.e. 2022.1. Can you update your Vtune profiler (2022.3) to the most recent version and test it?
Link: https://www.intel.com/content/www/us/en/developer/tools/oneapi/vtune-profiler-download.html
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
Vaibhav_S_Intel
Hi Jaideep,
I tried initially with the latest Vtune as well. I still see the same issue-- assertion failure on ADL based systems. I'm using sepdk build as the driver that came along with Vtune
Vaibhav_S_Intel
attached latest logs from vtune
JaideepK_Intel
As per system requirements, we can not run Vtune on Chrome OS. Can you try to run Vtune on a supporting operating system? and if the issue still persists, please let us know.
Jaideep
JaideepK_Intel
Jaideep
Vaibhav_S_Intel
Sorry i dont have acces to other OS and i mainly work on ChromeOS. I need Vtune team to support me on that.
JaideepK_Intel
We are working on this internally and get back to you with an update.
Thanks and Regards,
Jaideep
JaideepK_Intel
As we discussed privately, we are closing this case from our end. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
