Analyzers
5277 Discussions
Vtune not working properly for SGX-hotspot
jing
I am new to vtune. I am currently running vtune_profiler_2020.2.0.610396 on my Ubuntu 18.04 machine with intel i7-7700 cpu. However, when I try to run "vtune -collect sgx-hotspots -- /mayapp", the error message shows:
vtune: Error: Cannot enable Hardware Event-based Sampling due to a problem with the driver (sep*/sepdrv*). Check that the driver is running and the driver group is in the current user group list. See the "Sampling Drivers" help topic for further details.
I then checked the sep condition with "./insmod-sep -q" and I got
pax driver is loaded and owned by group "vtune" with file permissions "660".
socperf3 driver is not correctly loaded.
sep5 driver is not correctly loaded.
socwatch driver is loaded.
vtsspp driver is loaded and owned by group "vtune" with file permissions "660".
And I also tried to stop and restart the sep:
$sudo ./rmmod-sep -s
Removing sep5 driver from the kernel ... done.
The sep5 driver has been successfully unloaded.
Removing vtsspp driver from the kernel ... done.
The vtsspp driver has been successfully unloaded.
Removing socwatch2_12 driver from the kernel ... done.
The socwatch2_12 driver has been successfully unloaded.
Removing socperf3 driver from the kernel ... done.
The socperf3 driver has been successfully unloaded.
Attempting to stop PAX service ...
Removing pax driver from the kernel ... done.
The pax driver has been successfully unloaded.
PAX service has been stopped.
$sudo ./insmod-sep
Checking for PMU arbitration service (PAX) ... not detected.
Attempting to start PAX service ...
Executing: insmod ./pax/pax-x32_64-5.4.0-42-genericsmp.ko
Setting group ownership of devices to group "vtune" ... done.
Setting file permissions on devices to "660" ... done.
The pax driver has been successfully loaded.
PAX service has been started.
Checking for socperf driver ... not detected.
Executing: insmod ./socperf/src/socperf3-x32_64-5.4.0-42-genericsmp.ko
The socperf3 driver has been successfully loaded.
Executing: insmod ./sep5-x32_64-5.4.0-42-genericsmp.ko
The sep5 driver has been successfully loaded.
Checking for vtsspp driver ... not detected.
Executing: insmod ./vtsspp/vtsspp-x32_64-5.4.0-42-genericsmp.ko gid=1004 mode=0660 sym_lookup_func_addr="ffffffffb55554b0"
The vtsspp driver has been successfully loaded.
Checking for socwatch driver ... not detected.
Executing: insmod ./socwatch/drivers/socwatch2_12.ko
The socwatch driver has been successfully loaded.
 I was wondering what might be the issue? Thanks!
Kirill_U_Intel
Looks like all fine with sep output and drivers now.
Could you tell me is collection ok now?
Kirill
Kirill_U_Intel
could you provide output from vtune tool?
VTUNE_INSTAL_DIR/bin64/sep -version.
also could you remove drivers, clean dmesg, insmod drivers and provide dmesg output?
./rmmod-sep
dmesg -c
./insmod-sep
dmesg
Thanks, Kirill
jing
Sorry for the late reply. The sep version is below:
Sampling Enabling Product version: 5.19 Beta built on Jun 24 2020 16:46:20
SEP User Mode Version: 5.19 Beta
SEP Driver Version: 5.19 Beta (public)
PAX Driver Version: 1.0
Platform type: 117
CPU name: Intel(R) Processor code named Kabylake
PMU: skylake
Driver configs: Non-Maskable Interrupt, REGISTER CHECK ON
Copyright(C) 2007-2019 Intel Corporation. All rights reserved.
Part of the dmesg is attached here:
PAX: PMU arbitration service v1.0.2 has been started.
[1475906.702965] socperf3_0: SocPerf Driver loading...
[1475906.702967] socperf3_0: SocPerf Driver about to register chrdev...
[1475906.702969] socperf3_0: SocPerf Driver: result of alloc_chrdev_region is 0
[1475906.702970] socperf3_0: SocPerf Driver: major number is 236
[1475906.702972] socperf3_0: SocPerf Driver: detected 8 CPUs in lwpmudrv_Load
[1475906.702973] socperf3_0: SocPerf Driver: creating device socperf3!c...
[1475906.703079] socperf3_0: PMU check enabled! F6.M9e.S9 index=-1
[1475906.703080] socperf3_0: No MMIO list information detected!
[1475906.703081] socperf3_0: SocPerf Driver v3.0.0 has been loaded.
[1475907.723902] sep5_19: Driver loading...
[1475907.735444] sep5_19: [load] [UTILITY_Driver_Log_Init@1012]: Initialized driver log using contiguous physical memory.
[1475907.735449] sep5_19: [load] [lwpmu_Load@6431]: Major number is 235
[1475907.735452] sep5_19: [load] [lwpmu_Load@6438]: Detected 8 total CPUs and 8 active CPUs.
[1475907.736626] sep5_19: [load] [lwpmu_Load@6708]: PMU collection driver v5.19.6 Beta has been loaded.
[1475907.736627] sep5_19: [load] [lwpmu_Load@6714]: NMI will be used for handling PMU interrupts.
[1475907.736630] sep5_19: [load] [PMU_LIST_Initialize@655]: PMU check enabled! F6.M9e.S9 index=3 drv_type=PUBLIC
[1475907.736645] sep5_19: [load] [PMU_LIST_Build_PCI_List@701]: No PCI list information detected!
[1475908.918912] vtsspp: Driver version 1.8.226-610396
[1475908.918958] vtsspp: Kernel version 5.4.0-42-generic
[1475908.918959] vtsspp: Detected 8 CPUs
[1475908.918959] vtsspp: CPU family: 0x06, model: 0x9e, stepping: 09, HT: yes
[1475908.918960] vtsspp: CPU freq: 2903999KHz, timer freq: 1000000KHz
[1475908.918961] vtsspp: PMU: fixed counters: 3, general counters: 4
[1475908.919654] vtsspp: KPTI is enabled
[1475908.919655] vtsspp: KASLR is detected
[1475908.919655] vtsspp: Driver has been loaded
[1475908.927087] -----------------------------------------
[1475908.927088] OK: LOADED SoC Watch Driver
[1475908.927088] -----------------------------------------
[1478215.373051] audit: type=1400 audit(1600443882.075:2853): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd" name="/run/systemd/users/101277" pid=22910 comm="krb5_child" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1478215.400166] audit: type=1400 audit(1600443882.103:2854): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd" name="/usr/lib/x86_64-linux-gnu/krb5/plugins/authdata/sssd_pac_plugin.so" pid=22910 comm="krb5_child" requested_mask="m" denied_mask="m" fsuid=101277 ouid=0
[1478217.452161] sep5_19: [load] [lwpmu_Unload@6749]: Driver unloading.
[1478217.480464] sep5_19: PMU collection driver v5.19.6 Beta has been unloaded.
[1478219.552333] vtsspp: Driver has been unloaded
[1478221.611341] -----------------------------------------
[1478221.611344] OK: UNLOADED SoC Watch Driver
[1478221.611345] -----------------------------------------
[1478223.738031] socperf3_0: SocPerf Driver unloading...
[1478223.738290] socperf3_0: SocPerf Driver v3.0.0 has been unloaded.
[1478225.813925] PAX: PMU arbitration service v1.0.2 has been stopped.
[1478237.022834] PAX: PMU arbitration service v1.0.2 has been started.
[1478238.131298] socperf3_0: SocPerf Driver loading...
[1478238.131300] socperf3_0: SocPerf Driver about to register chrdev...
[1478238.131303] socperf3_0: SocPerf Driver: result of alloc_chrdev_region is 0
[1478238.131305] socperf3_0: SocPerf Driver: major number is 236
[1478238.131306] socperf3_0: SocPerf Driver: detected 8 CPUs in lwpmudrv_Load
[1478238.131308] socperf3_0: SocPerf Driver: creating device socperf3!c...
[1478238.131513] socperf3_0: PMU check enabled! F6.M9e.S9 index=-1
[1478238.131516] socperf3_0: No MMIO list information detected!
[1478238.131518] socperf3_0: SocPerf Driver v3.0.0 has been loaded.
[1478239.148503] sep5_19: Driver loading...
[1478239.149443] sep5_19: [load] [UTILITY_Driver_Log_Init@1012]: Initialized driver log using contiguous physical memory.
[1478239.149451] sep5_19: [load] [lwpmu_Load@6431]: Major number is 235
[1478239.149460] sep5_19: [load] [lwpmu_Load@6438]: Detected 8 total CPUs and 8 active CPUs.
[1478239.151473] sep5_19: [load] [lwpmu_Load@6708]: PMU collection driver v5.19.6 Beta has been loaded.
[1478239.151477] sep5_19: [load] [lwpmu_Load@6714]: NMI will be used for handling PMU interrupts.
[1478239.151486] sep5_19: [load] [PMU_LIST_Initialize@655]: PMU check enabled! F6.M9e.S9 index=3 drv_type=PUBLIC
[1478239.151530] sep5_19: [load] [PMU_LIST_Build_PCI_List@701]: No PCI list information detected!
[1478240.260114] vtsspp: Driver version 1.8.226-610396
[1478240.260164] vtsspp: Kernel version 5.4.0-42-generic
[1478240.260165] vtsspp: Detected 8 CPUs
[1478240.260166] vtsspp: CPU family: 0x06, model: 0x9e, stepping: 09, HT: yes
[1478240.260166] vtsspp: CPU freq: 2903999KHz, timer freq: 1000000KHz
[1478240.260167] vtsspp: PMU: fixed counters: 3, general counters: 4
[1478240.260949] vtsspp: KPTI is enabled
[1478240.260950] vtsspp: KASLR is detected
[1478240.260950] vtsspp: Driver has been loaded
[1478240.267964] -----------------------------------------
[1478240.267965] OK: LOADED SoC Watch Driver
[1478240.267965] -----------------------------------------
[1517399.296773] audit: type=1400 audit(1600483065.727:2855): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd" name="/usr/lib/x86_64-linux-gnu/krb5/plugins/authdata/sssd_pac_plugin.so" pid=25738 comm="krb5_child" requested_mask="m" denied_mask="m" fsuid=101277 ouid=0
[1544730.757598] audit: type=1400 audit(1600510396.998:2856): apparmor="ALLOWED" operation="exec" profile="/usr/sbin/sssd" name="/usr/sbin/adcli" pid=28187 comm="sssd_be" requested_mask="x" denied_mask="x" fsuid=0 ouid=0 target="/usr/sbin/sssd//null-/usr/sbin/adcli"
[1544730.758935] audit: type=1400 audit(1600510396.998:2857): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/sbin/adcli" pid=28187 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1544730.759218] audit: type=1400 audit(1600510397.002:2858): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/lib/x86_64-linux-gnu/ld-2.27.so" pid=28187 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1544730.759529] audit: type=1400 audit(1600510397.002:2859): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/etc/ld.so.cache" pid=28187 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1544730.759553] audit: type=1400 audit(1600510397.002:2860): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2" pid=28187 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1544730.759675] audit: type=1400 audit(1600510397.002:2861): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2" pid=28187 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1544730.759804] audit: type=1400 audit(1600510397.002:2862): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libkrb5.so.3.3" pid=28187 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1544730.759811] audit: type=1400 audit(1600510397.002:2863): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libkrb5.so.3.3" pid=28187 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1544730.759962] audit: type=1400 audit(1600510397.002:2864): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1" pid=28187 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1544730.759978] audit: type=1400 audit(1600510397.002:2865): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1" pid=28187 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1631131.358009] kauditd_printk_skb: 132 callbacks suppressed
[1631131.358012] audit: type=1400 audit(1600596796.997:2998): apparmor="ALLOWED" operation="exec" profile="/usr/sbin/sssd" name="/usr/sbin/adcli" pid=1396 comm="sssd_be" requested_mask="x" denied_mask="x" fsuid=0 ouid=0 target="/usr/sbin/sssd//null-/usr/sbin/adcli"
[1631131.359077] audit: type=1400 audit(1600596796.997:2999): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/sbin/adcli" pid=1396 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1631131.359123] audit: type=1400 audit(1600596796.997:3000): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/lib/x86_64-linux-gnu/ld-2.27.so" pid=1396 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1631131.359328] audit: type=1400 audit(1600596796.997:3001): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/etc/ld.so.cache" pid=1396 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1631131.359412] audit: type=1400 audit(1600596796.997:3002): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2" pid=1396 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1631131.359441] audit: type=1400 audit(1600596796.997:3003): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2" pid=1396 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1631131.359540] audit: type=1400 audit(1600596796.997:3004): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libkrb5.so.3.3" pid=1396 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1631131.359564] audit: type=1400 audit(1600596796.997:3005): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libkrb5.so.3.3" pid=1396 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1631131.359655] audit: type=1400 audit(1600596796.997:3006): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1" pid=1396 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1631131.359725] audit: type=1400 audit(1600596796.997:3007): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1" pid=1396 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1717531.957735] kauditd_printk_skb: 132 callbacks suppressed
[1717531.957738] audit: type=1400 audit(1600683196.998:3140): apparmor="ALLOWED" operation="exec" profile="/usr/sbin/sssd" name="/usr/sbin/adcli" pid=6653 comm="sssd_be" requested_mask="x" denied_mask="x" fsuid=0 ouid=0 target="/usr/sbin/sssd//null-/usr/sbin/adcli"
[1717531.958970] audit: type=1400 audit(1600683196.998:3141): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/sbin/adcli" pid=6653 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1717531.959012] audit: type=1400 audit(1600683196.998:3142): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/lib/x86_64-linux-gnu/ld-2.27.so" pid=6653 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1717531.959227] audit: type=1400 audit(1600683197.002:3143): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/etc/ld.so.cache" pid=6653 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1717531.959301] audit: type=1400 audit(1600683197.002:3144): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2" pid=6653 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1717531.959343] audit: type=1400 audit(1600683197.002:3145): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2" pid=6653 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1717531.959507] audit: type=1400 audit(1600683197.002:3146): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libkrb5.so.3.3" pid=6653 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1717531.959515] audit: type=1400 audit(1600683197.002:3147): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libkrb5.so.3.3" pid=6653 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1717531.959643] audit: type=1400 audit(1600683197.002:3148): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1" pid=6653 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1717531.959651] audit: type=1400 audit(1600683197.002:3149): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1" pid=6653 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1742292.411242] kauditd_printk_skb: 132 callbacks suppressed
[1742292.411243] audit: type=1400 audit(1600707957.277:3282): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd" name="/usr/lib/x86_64-linux-gnu/krb5/plugins/authdata/sssd_pac_plugin.so" pid=9009 comm="krb5_child" requested_mask="m" denied_mask="m" fsuid=101277 ouid=0
[1803932.554639] audit: type=1400 audit(1600769596.999:3283): apparmor="ALLOWED" operation="exec" profile="/usr/sbin/sssd" name="/usr/sbin/adcli" pid=12946 comm="sssd_be" requested_mask="x" denied_mask="x" fsuid=0 ouid=0 target="/usr/sbin/sssd//null-/usr/sbin/adcli"
[1803932.555105] audit: type=1400 audit(1600769596.999:3284): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/sbin/adcli" pid=12946 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1803932.555108] audit: type=1400 audit(1600769596.999:3285): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/lib/x86_64-linux-gnu/ld-2.27.so" pid=12946 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1803932.555200] audit: type=1400 audit(1600769596.999:3286): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/etc/ld.so.cache" pid=12946 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1803932.555202] audit: type=1400 audit(1600769596.999:3287): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2" pid=12946 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1803932.555204] audit: type=1400 audit(1600769596.999:3288): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2" pid=12946 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1803932.555269] audit: type=1400 audit(1600769596.999:3289): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libkrb5.so.3.3" pid=12946 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1803932.555272] audit: type=1400 audit(1600769596.999:3290): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libkrb5.so.3.3" pid=12946 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1803932.555332] audit: type=1400 audit(1600769596.999:3291): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1" pid=12946 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1803932.555335] audit: type=1400 audit(1600769596.999:3292): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1" pid=12946 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1890333.152552] kauditd_printk_skb: 132 callbacks suppressed
[1890333.152563] audit: type=1400 audit(1600855996.999:3425): apparmor="ALLOWED" operation="exec" profile="/usr/sbin/sssd" name="/usr/sbin/adcli" pid=19087 comm="sssd_be" requested_mask="x" denied_mask="x" fsuid=0 ouid=0 target="/usr/sbin/sssd//null-/usr/sbin/adcli"
[1890333.153608] audit: type=1400 audit(1600855996.999:3426): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/sbin/adcli" pid=19087 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1890333.153620] audit: type=1400 audit(1600855996.999:3427): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/lib/x86_64-linux-gnu/ld-2.27.so" pid=19087 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1890333.153810] audit: type=1400 audit(1600855996.999:3428): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/etc/ld.so.cache" pid=19087 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1890333.153869] audit: type=1400 audit(1600855996.999:3429): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2" pid=19087 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1890333.153907] audit: type=1400 audit(1600855996.999:3430): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2" pid=19087 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1890333.154049] audit: type=1400 audit(1600855997.003:3431): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libkrb5.so.3.3" pid=19087 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1890333.154071] audit: type=1400 audit(1600855997.003:3432): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libkrb5.so.3.3" pid=19087 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1890333.154208] audit: type=1400 audit(1600855997.003:3433): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1" pid=19087 comm="adcli" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1890333.154242] audit: type=1400 audit(1600855997.003:3434): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd//null-/usr/sbin/adcli" name="/usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1" pid=19087 comm="adcli" requested_mask="rm" denied_mask="rm" fsuid=0 ouid=0
[1923834.103063] kauditd_printk_skb: 132 callbacks suppressed
[1923834.103064] audit: type=1400 audit(1600889497.719:3567): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd" name="/usr/lib/x86_64-linux-gnu/krb5/plugins/authdata/sssd_pac_plugin.so" pid=22521 comm="krb5_child" requested_mask="m" denied_mask="m" fsuid=101277 ouid=0
[1924564.148672] audit: type=1400 audit(1600890227.757:3568): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd" name="/run/systemd/users/101277" pid=22730 comm="krb5_child" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[1924564.337977] audit: type=1400 audit(1600890227.949:3569): apparmor="ALLOWED" operation="file_mmap" profile="/usr/sbin/sssd" name="/usr/lib/x86_64-linux-gnu/krb5/plugins/authdata/sssd_pac_plugin.so" pid=22730 comm="krb5_child" requested_mask="m" denied_mask="m" fsuid=101277 ouid=0
[1924880.983796] sep5_19: [load] [lwpmu_Unload@6749]: Driver unloading.
[1924881.056709] sep5_19: PMU collection driver v5.19.6 Beta has been unloaded.
[1924883.084125] vtsspp: Driver has been unloaded
[1924885.139227] -----------------------------------------
[1924885.139230] OK: UNLOADED SoC Watch Driver
[1924885.139232] -----------------------------------------
[1924887.253609] socperf3_0: SocPerf Driver unloading...
[1924887.253888] socperf3_0: SocPerf Driver v3.0.0 has been unloaded.
[1924889.323918] PAX: PMU arbitration service v1.0.2 has been stopped.
[1925044.406231] PAX: PMU arbitration service v1.0.2 has been started.
[1925045.484564] socperf3_0: SocPerf Driver loading...
[1925045.484565] socperf3_0: SocPerf Driver about to register chrdev...
[1925045.484565] socperf3_0: SocPerf Driver: result of alloc_chrdev_region is 0
[1925045.484566] socperf3_0: SocPerf Driver: major number is 236
[1925045.484566] socperf3_0: SocPerf Driver: detected 8 CPUs in lwpmudrv_Load
[1925045.484567] socperf3_0: SocPerf Driver: creating device socperf3!c...
[1925045.484679] socperf3_0: PMU check enabled! F6.M9e.S9 index=-1
[1925045.484680] socperf3_0: No MMIO list information detected!
[1925045.484680] socperf3_0: SocPerf Driver v3.0.0 has been loaded.
[1925046.500871] sep5_19: Driver loading...
[1925046.501801] sep5_19: [load] [UTILITY_Driver_Log_Init@1012]: Initialized driver log using contiguous physical memory.
[1925046.501809] sep5_19: [load] [lwpmu_Load@6431]: Major number is 235
[1925046.501818] sep5_19: [load] [lwpmu_Load@6438]: Detected 8 total CPUs and 8 active CPUs.
[1925046.504222] sep5_19: [load] [lwpmu_Load@6708]: PMU collection driver v5.19.6 Beta has been loaded.
[1925046.504226] sep5_19: [load] [lwpmu_Load@6714]: NMI will be used for handling PMU interrupts.
[1925046.504235] sep5_19: [load] [PMU_LIST_Initialize@655]: PMU check enabled! F6.M9e.S9 index=3 drv_type=PUBLIC
[1925046.504282] sep5_19: [load] [PMU_LIST_Build_PCI_List@701]: No PCI list information detected!
[1925047.611183] vtsspp: Driver version 1.8.226-610396
[1925047.611232] vtsspp: Kernel version 5.4.0-42-generic
[1925047.611233] vtsspp: Detected 8 CPUs
[1925047.611233] vtsspp: CPU family: 0x06, model: 0x9e, stepping: 09, HT: yes
[1925047.611234] vtsspp: CPU freq: 2903999KHz, timer freq: 1000000KHz
[1925047.611235] vtsspp: PMU: fixed counters: 3, general counters: 4
[1925047.611933] vtsspp: KPTI is enabled
[1925047.611933] vtsspp: KASLR is detected
[1925047.611934] vtsspp: Driver has been loaded
[1925047.618546] -----------------------------------------
[1925047.618547] OK: LOADED SoC Watch Driver
[1925047.618547] -----------------------------------------
Just let me know if more information is needed. Thanks!
Kirill_U_Intel
Kirill
jing
AthiraM_Intel
Could you please provide the above mentioned details.
AthiraM_Intel
Glad to know that your issue got resolved. We would discontinue monitoring this thread, please raise a new thread if you have further issues.
