Analyzers
5285 Discussions
Assertion failed: pytrace_tracewriter:341: (jitWriterReady) : . Please contact the technical support
dnegtech
Hi everyone,
We're having this issue, any analysis shows the screenshot as attached, with a process spinning on one cpu and not doing anything.
Version: vtune_profiler_2020.2.0.610396
OS: linux centos76
These are some of the error logs:
/apps/Linux64/intel/vtune_profiler_2020/bin64/vtune-gui: /lib64/libdbus-1.so.3: no version information available (required by /apps/Linux64/intel/vtune_profiler_2020/bin64/vtune-gui)
Fontconfig warning: "/etc/fonts/fonts.conf", line 86: unknown element "blank"
Intel VTune Profiler log directory is invalid. Security permissions are insufficient. Make sure to limit the directory access to exclude 'other' write permissions.
AMPLXE_TPSSCOLLECTOR: pytrace_tracewriter:341: (jitWriterReady) :
Assertion failed: pytrace_tracewriter:341: (jitWriterReady) : . Please contact the technical support.
Please advise, thanks.
Yours Sincerely,
Kai
Aleksei_O
Hello, Kai. Thank you for reporting this issue. This problem will be fixed in next VTune release. Is there anything I can help you?
JananiC_Intel
Thanks for posting in Intel forums.
You can try vtune-self-checker.sh script from <install_dir>/bin64 directory.This self checker script is used to validate the installations and system setup.So try running that and let us know the result.Also make sure whether you have write permission to the path,where the result will be written.
Aleksei_O
dnegtech
Thank you both.
I have informed the Software Developer team and will keep you posted if there are feedbacks from them.
Yours Sincerely,
Kai
JananiC_Intel
Do you have any updates?Can we close the case?
JananiC_Intel
Hope we have answered your query .We would discontinue monitoring this issue.Please raise a new thread if you have further issues.
