Analyzers
Vtune -report time
Ryan8
Relatively new user to VTune, and we had hopefully simple question. We are trying to acquire different CPU/Memory characteristics over time, not just summary. We are able to reproduce a previous post that showed how to do it for OvertimeBandwidth using the following command:
vtune -report time -r r010macc -knob column-by=OvertimeBandwidth -r-k bin-count=50
However, we are trying to do the same thing for L1D Cache misses or Branch mispredictions. Does anyone know what are the possibilities for column-by?
Thanks!
AthiraM_Intel
We are checking on it internally, will get back to you soon with an update.
Could you please share the vtune version?
Dmitry_R_Intel1
Here is an example of command line to get overtime report for all events present in the result:
vtune -R time -r <result> -r-k column-by=PMUEventCount -r-k group_by=PMUEventType -r-k bin-count=50
There are some other possibilities - I would suggest to open the time report script located in <vtune-install-dir>/config/report/experimental.time-cl/time.tmpl and there will be some examples at the beginning which may be useful for you.
Ryan8
Hi Dmitry,
Thank you! That seems to be what we are looking for!
AthiraM_Intel
Hi Ryan8,
Glad to know that the solution provided by Dmitry_R_Intel1 helped you. If you need any additional information, please submit a new question as this thread will no longer be monitored.
