Analyzers
5272 Discussions
What is the formula of Data transfers between CPU and memory sub-system (total traffic, including L1, L2, LLC and DRAM traffic)?
Youwei_Z_
I can compute GLOPS based on #instructions and instruction type.
For example, I have 17694720000 FMA3, so I have 17694720000*3*8*3*8=283GFLOPS. Great! Intel advisor gives the same number.
However, how to get Data transfers between CPU and memory sub-system (total traffic, including L1, L2, LLC and DRAM traffic)? (The number in the bottom right. It does not match with #instructions for memory load.
AVX; FMA
Instruction Set
3.842s
Self time
Dynamic Instruction Mix Summary
Memory
34% (11796480000)
Vector
34% (11796480000)
AVX
34% (11796480000)
Compute
57% (19722240000)
Vector
51% (17694720000)
FMA
51% (17694720000)
Scalar
6% (2027520000)
x86
6% (2027520000)
Other
9% (3133440000)
Statistics for FLOPS And Data Transfers
Self GFLOPS 808.89193 Giga Floating-point Operations Per Second
Self GFLOPS = Self GFLOP / Self Elapsed Time
Self AI 2.18182 Self AI - Self Arithmetic Intensity - Ratio Of Self Floating-Point Operations To Self L1 Transferred Bytes
Self GFLOP 283.11552 Giga Floating-Point Operations, Not Including GFLOP For Functions Called In The Loop Or Function
Self Elapsed Time 0.350s Elapsed Time Is The Exclusive (Self-Time-Based) Wall Time From The Beginning To The End Of Loop/Function Execution. For Single-Threaded Applications Elapsed Time Is Equal To Self-Time
Total Elapsed Time 0.350s Total Elapsed Time Is The Inclusive (Total-Time-Based) Wall Time From The Beginning To The End Of Loop/Function Execution. For Single-Threaded Applications Total Elapsed Time Is Equal To Total-Time
In Giga Bytes, Not Including Transfers For Functions Called In The Loop Or Function 129.76128
In Giga Bytes Per Second 370.74213
