Where can I find Input and Output Analysis in version 2023.2?
Thank you for posting in Intel Communities. Please view Input and output analysis in VTune Profiler (2023.2) by following the below steps:
- Launch VTune Profiler and, optionally, create a new project.
- Click the Configure Analysis button.
- In the WHERE pane, select the target system to profile.
- In the WHAT pane, specify your analysis target (application, process, or system).
- In HOW pane, select SYSTEM OVERVIEW analysis.
- Depending on your target app and analysis purpose, choose any of the configuration options described in sections below.
- Click Start to run the analysis.
- VTune Profiler collects the data, generates a result, and opens the result with that displays data according to configuration.
- In the Summary tab, click on the drop-down menu as highlighted in the below pictures & select Input and Output.
Instead, you could also run the Input and Output analysis from the command line, enter:
vtune -collect io [-knob <value>] -- <target> [target_options]
For details, see the io command line reference.
If this resolves your query make sure to accept this as solution. This helps others with similar queries.
Alekhya
Alekhya
Has the solution provided helped? Please give us an update regarding your issue. Can we close this thread?
Alekhya
We have not heard back from you, hence we are closing this thread now. If you need any further information, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
