Analyzers
Windows XP x64 BSOD
nospamnerd
I am trying to run VTune 7.2.034 on a Windows XP x64 Pro machine (dual Intel Xeon EM64T). After installing the software I started getting random Blue Screen of Deaths. I can start VTune and shortly after I get another BSOD.
Windows Help said the error was a driver problem. As soon as I uninstall VTune my system goes back to working as normal.
Error code 0000000000000109, parameter1 a3a03a382eb3b97f, parameter2 b3b746be8130609c, parameter3 fffff80001001000, parameter4 0000000000000000.
David_A_Intel1
If you are registered for technical support, you should have received an email notifiying you of an update that resolves this problem. You can download the file vpa_7.2_pp1.zip from Intel Premier Support, in the File Downloads area for the VTune Performance Analyzer (select this name in the Product drop down list and press Display File List).
If you did not opt-in to technical support, please return to the registration center and log in. Once logged in, click on Intel Premier Support. You should be prompted to create you account at that point. If not, please send an email requesting an account to [email protected].
nospamnerd
This update does fix my problem.
