Analyzers
5272 Discussions
a problem in vtune for linux 1.0 on redhat8.0
gfzhang
Ihave installed the VTune Performance Analysis 1.1 for Linux in Redhat8.0.
But I can't run any activity.
For example, I use command: vtl activity -c sampling run
The infoomation it give out:
The Activity is running.
Fri May 27 23:02:13 2005 localhost (Run 0) The sampling Collector is calibrating its collection parameters for the following event(s): Instructions Retired, Clockticks.
Fri May 27 23:02:13 2005 localhost (Run 0) The sampling Collector iscollecting samples based on the following event(s): Instructions Retired, Clockticks.
Fri May 27 23:02:13 2005 localhost (Run 0) The sampling Collector failed to collect data because the selected even(s) did not occur.
The Activity has finished running.
Why didn't the selected evens occur?
What I have to do?
Thanks!
David_A_Intel1
Thanks correct! If you check the Release Notes you will see that 8.0 was not supported by version 1.1 of the VTune analyzer for Linux.
Version 3.0 is the currently available release and theonly versionto support 8.0.
