Analyzers
5250 Discussions
amplxe: Error: 0x40000025 (Inapplicable report) -- The report 'summary' is not applicable to the result
taiyu__zhou
Hi guys!
I am trying to use amplxe-cl to run the sample program nqueens_parallerl .But it don't work.
I run
amplxe-cl -collect hotspots -result-dir /root/taya/r0001hs -- ./nqueens_parallel 15
and it report that:
amplxe: Collection started. To stop the collection, either press CTRL-C or enter from another console window: amplxe-cl -r /root/taya/r0001hs -command stop.
A: Source/pin/base_l/sysfuncs_linux.cpp: IA32E_CHECK: 136: assertion failed: result != -1
## STACK TRACE
amplxe: Collection stopped.
amplxe: Using result path `/root/taya/r0001hs'
amplxe: Executing actions 100 % done
amplxe: Error: 0x40000025 (Inapplicable report) -- The report 'summary' is not applicable to the result /root/taya/r0001hs/r0001hs.amplxe.
Give me some advice ,thanks!
Andrey_I_Intel
Hi!
Could you please specify what version of VTune and OS are you trying with?
