Analyzers
5271 Discussions
an error report occure each time I try to create a new project (license was not found)
chobanu_p_m1
Hello!
I'v downloaded a trial version of VTune and installed it. I can run it, i can open en EXE-file, but, for instance, if I'm trying to create a new project, a window, telling me, that a license was not found apeares.
It tells: "A license for Intel VTune Performance Analyser was not found. Please ensure that a valid license file is in the directory <>. If the condition persists, please contact Consumer Support at http://premier.intel.com."
The license file, I'v got from you by e-mail with the license code is in the mentioned folder.
When I try to load the page http://premier.intel.com, i get an error: "An unexpected error has occurred!
Please go back and try your action again.
If you continue to have problems, contact
Premier Support using the Feedback link above."
How can I solve the problem?
regards,
Petr
David_A_Intel1
Hi Petr:
For the Premier problem, please try opening https://premier.intel.com.
Regarding the VTune analyzer problem, the eval license does not enable persisting any data, this included projects. If you have already collected data, when you attempt to create a "new" project, the VTune analyzer is attempting to save the old one. thus the error message.
With the eval license, you should be able to 1) create an activity, 2) collect data, 3) view and analyze the data. This should enable you to make the determination of whether or not to purchase the product.
chobanu_p_m1
Hi Petr:
when I try to create an activity (menu file->new project->call graph wizard or file->new project->sampling wizard) I get the same error
Peter_W_Intel
Quoting - chobanu_p_m
Don't know if there are other eval (expired) license files under , pleasemove them to other place, just put your new license (from email - not expired) only, and reenter VTune Analyzer.
Regards, Peter
