Analyzers
5282 Discussions
bsod when running the vtune profiler
Mc_Lovin
Hello I am getting a bsod when running the intel vtune profiler debug application: SYSTEM_SERVICE_EXCEPTION
error code: 0x0000003b
parameter1: 00000000`c0000005
parameter2: fffff801`442ae82c
parameter3: ffffd88`dfd35f60
parameter4: 00000000`00000000
cause driver: ntoskrnl.exe
file version: 10.0.22621.2215 (WinBuild.160101.0800)
And that is not all.
I have updated all asus and intel drivers but nothing helps.
After a blue screen and a system reboot, the application works, but after I turn the computer on and off again, a blue screen appears again when the application starts.
Restoring windows with removing all programs and cleaning the disk also does not help.
ThasneemV_Intel
Could you please share the following details:
1. Sample reproducer code.
2. VTune version.
3. Exact steps and the commands used.
4. OS, kernel and Processor details.
5. Self-checker logs.
The "vtune-self-checker.sh" script is available from <install-dir>/bin64 on the Windows or Linux system on which you installed VTune Profiler.
On running this script, it will create a log file and display the location of the log file. Kindly share that file with us so we can verify it from our side.
Thasneem Vazim
Mc_Lovin
Thanks for the answer!
I reset the laptop to factory settings as there were other problems. Now the blue screen is gone, but there is another problem with vtune, here is the link Microarchitecture exploration tab - Intel Community
ThasneemV_Intel
Good day to you!
Glad to know that your initial issue is resolved. Intel will no longer monitor this thread.
Since you have opened a new thread Microarchitecture exploration tab - Intel Community for the new issue, we will address it there.
Thasneem Vazim
