Analyzers
can't open Fortran in Visual Studio 2017 tool path is not existing
wang__zhenyu
error /bin32,tool path is not existing
i had installed the vs2017 before the  parallel studio but after that i still can't built a empty Fortran project.
who can help me ?
thanks a lot!
Elizaveta_P_Intel
Hi, friend,
This error happens when some of the following environment variables are not set:
  • VTUNE_AMPLIFIER_2019_DIR=%Path to install directory of Amplifier%. The default is C:\Program Files (x86)\IntelSWTools\VTune Amplifier 2019.
  • ADVISOR_2019_DIR=%Path to install directory of Advisor%. The default is C:\Program Files (x86)\IntelSWTools\Advisor 2019.
  • INSPECTOR_2019_DIR=%Path to install directory of Inspector%. The default is  C:\Program Files (x86)\IntelSWTools\Inspector 2019.
Could you check them out? And in case of absence, please provide them.
The year in the name of variable can be different depending of the version used.
