Analyzers
5342 Discussions
can't recognize script as executable file.
Qun_L_
I have installed the Vtune in a new computer, but it showed:
amplxe: Error: File "/home/SPEC/cpu2006/scripts/runastar" is not an executable binary.
It works well in my previous computer, does anyone knows this problem?
Thank you.
Ekaterina_L_Intel
Please run:
chmod 755 /home/SPEC/cpu2006/scripts/runastar
Regards, Katya
Ekaterina_L_Intel
Please check `ls -g /home/SPEC/cpu2006/scripts/runastar` command output and make sure the file has executable bit ON for owner and group at least.
Regards, Katya
Qun_L_
Regards, Katya
Hi Katya,
Thank you for this. I have thought about a bit of this, I am newer for ubuntu, so if it is not ON, how should I do for making this ON to this file?
Thank you.
Ekaterina_L_Intel
Please run:
Regards, Katya
Qun_L_
Please run:
Regards, Katya
Hi Katya,
Thank you so much for your help, it works now :)
Qun_L_
Please run:
Regards, Katya
Hi Katya,
DO you know this problem?
It works well when I run spec using amplxe-cl, but it did not output csv file, which I have defined it in script, but this can work in my previous computer.
This is the script:
/opt/intel/vtune_amplifier_xe_2016/bin64/amplxe-cl --collect custom-analysis-0 -follow-child -target-duration-type=short -allow-multiple-runs -no-analyze-system -data-limit=100 -result-dir=/home/foo/intel/MyAmplifierProjects/intel_test3/astar  -- /home/foo/SPEC/QUN/SPEC/cpu2006/scripts/runastar
/opt/intel/vtune_amplifier_xe_2016/bin64/amplxe-cl -report summary -format csv -report-output=/home/foo/intel/MyAmplifierProjects/intel_test3/astar -r /home/foo/intel/MyAmplifierProjects/intel_test3/astar
Thank you.
Ekaterina_L_Intel
I see that you use custom analysis.
Please make sure the "custom-analysis-0.cfg" is available on the new system in the `$HOME/.intel/amplxe/analysis_type` location.
Regards, Katya
Qun_L_
Regards, Katya
Thank you, I have solved this problem.
Have a nice day.
Ekaterina_L_Intel
Good to know! Thanks for letting us know ;-)
Regards, Katya
liu__kevin
Regards, Katya
Hi Katya,
can you help me with this problem?
https://software.intel.com/en-us/forums/intel-vtune-amplifier-xe/topic/697113
thank you.
