Analyzers
scratch space?
GhostRon_G_
Does Advisor create any temporary scratch files during collection?  If so, where and can one control the scratch area to use with TMPDIR or some other env var?
Ron
Kevin_O_Intel1
You can change the location where advisor saves it's files using the following menu File->Options->Result Location
Click on "Save All Results in this location"
Kevin
GhostRon_G_
I know about the results dir options - so what I'm hearing is that "no, Advisor does not use scratch files.  only results files are opened by the collector." - correct?
Ron
