Analyzers
5255 Discussions
crash when debugging is turned on
Marián__VooDooMan__M
New Contributor II
Greetings,
II have crash when run on Windows MSVC and I hit F5 to run with debugger attached. after few actions I get dialog:
Microsoft Visual Studio
The debugger's worker process (msvsmon.exe) unexpectedly exited. Debugging will be aborted.
OK
dialog to sent dump to MS reads:
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    msvsmon.exe
  Application Version:    12.0.21005.1
  Application Timestamp:    524f9c4c
  Fault Module Name:    ntdll.dll
  Fault Module Version:    6.3.9600.16408
  Fault Module Timestamp:    523d5305
  Exception Code:    c00000fd
  Exception Offset:    0000000000052e2e
  OS Version:    6.3.9600.2.0.0.256.48
  Locale ID:    1033
  Additional Information 1:    bf88
  Additional Information 2:    bf88fd355c14dcf55ea9e3a1a5fa749f
  Additional Information 3:    e712
  Additional Information 4:    e7129f01d567e84fac99ccbf926b7fdc
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=280262
If the online privacy statement is not available, please read our privacy statement offline:
  C:\WINDOWS\system32\en-GB\erofflps.txt
best,
New Contributor II
and the dialog tom MSVC reads:
OK
best,
vdm
New Contributor II
But w/o debugger attached, everything goes smoothly, w/o iteruption.
Peter_W_Intel
I wonder that you reported the problem which is MSVC issue?
1. Actually you didn't run VTune Amplifier XE anymore, ran F5 with debugger attached to cause this problem. Am I right?
2. Did it mean you met this problem after VTune integration installation, and cannot see this after uninstalling VTune Amplifier?
Thanks, Peter
Bernard
Valued Contributor I
I have the same issue.When I run VS debugger Visual Studio 2013 crashes so I switched to using windbg for testing my code at development stage.
Regarding @Marian case it seems that exception code is related to stack overflow.
Bernard
@Peter
In my case the crash occurred after VTune integration.
Btw. few weeks ago a very similar issue was described in now defunct Parallel Studio forum when it was found that some of the Intel integrated debugger components caused infinite recursive function call.
Peter_W_Intel
@ iliyapolak
Are you sure it was caused by VTune Amplifier XE? I mean if you uninstall the VTune integration, the problems goes.
Peter_W_Intel
Thanks for this report. Would you please send me call stack info? Core dump file is too big...
Run "amplxe-feedback -create-bug-report <report archive>" after crashing, send logs.zip to us so engineering will investigate. Thanks again.
Bernard
@Peter
Yes because before the integration I was using VS debugger without any problem.In spare time I plan to investigate that issue more in depth.
