Analyzers
5268 Discussions
current procedure for building i915 module?
CFR
New Contributor II
Lenovo T570, Ubuntu 18.04.4, 5.3.0-53-generic, OneAPI/Vtune 2021.1.0 beta06
I've been looking into building an i915 module so I can try CONFIG_DRM_I915_LOW_LEVEL_TRACEPOINTS=y to get at the low level information using VTune.  I tried the instructions in https://software.intel.com/content/www/us/en/develop/documentation/vtune-help/top/installation/set-up-system-for-gpu-analysis/rebuild-and-install-i915-module-ubuntu.html and get the following:
root@t570:~/OneAPI# sudo add-apt-repository -s "deb http://ru.archive.ubuntu/ bionic main restricted"
Hit:1 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Get:2 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Get:3 http://dl.google.com/linux/chrome/deb stable InRelease [1,811 B]
Get:4 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Get:6 http://ru.archive.ubuntu bionic InRelease
Err:6 http://ru.archive.ubuntu bionic InRelease
  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
Get:7 http://dl.google.com/linux/chrome/deb stable/main amd64 Packages [1,123 B]
Get:8 http://us.archive.ubuntu.com/ubuntu bionic-updates/main i386 Packages [685 kB]
Get:9 http://us.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [951 kB]
Get:10 http://us.archive.ubuntu.com/ubuntu bionic-updates/main Translation-en [324 kB]
Get:11 http://us.archive.ubuntu.com/ubuntu bionic-updates/main amd64 DEP-11 Metadata [306 kB]
Get:12 http://security.ubuntu.com/ubuntu bionic-security/main amd64 Packages [727 kB]
Get:13 http://us.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 48x48 Icons [81.9 kB]
Get:14 http://us.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 64x64 Icons [157 kB]
Get:15 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe i386 Packages [1,018 kB]
Get:16 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [1,077 kB]
Get:17 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe Translation-en [335 kB]
Get:18 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 DEP-11 Metadata [279 kB]
Get:19 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 48x48 Icons [213 kB]
Get:20 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 64x64 Icons [462 kB]
Get:21 http://security.ubuntu.com/ubuntu bionic-security/main i386 Packages [474 kB]
Get:22 http://us.archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 DEP-11 Metadata [2,464 B]
Get:23 http://us.archive.ubuntu.com/ubuntu bionic-backports/universe amd64 DEP-11 Metadata [7,968 B]
Get:24 http://security.ubuntu.com/ubuntu bionic-security/main Translation-en [230 kB]
Ign:25 https://repositories.intel.com/graphics/ubuntu bionic-devel InRelease
Get:26 https://repositories.intel.com/graphics/ubuntu bionic-devel Release [2,702 B]
Get:27 http://security.ubuntu.com/ubuntu bionic-security/main amd64 DEP-11 Metadata [43.8 kB]
Get:28 http://security.ubuntu.com/ubuntu bionic-security/main DEP-11 48x48 Icons [25.7 kB]
Get:29 http://security.ubuntu.com/ubuntu bionic-security/main DEP-11 64x64 Icons [58.0 kB]
Get:30 http://security.ubuntu.com/ubuntu bionic-security/universe i386 Packages [623 kB]
Get:31 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [669 kB]
Get:32 http://security.ubuntu.com/ubuntu bionic-security/universe Translation-en [222 kB]
Get:33 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 DEP-11 Metadata [49.2 kB]
Get:34 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 48x48 Icons [18.6 kB]
Get:35 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 64x64 Icons [107 kB]
Get:36 http://security.ubuntu.com/ubuntu bionic-security/multiverse amd64 DEP-11 Metadata [2,464 B]
Ign:37 https://repositories.intel.com/graphics/ubuntu bionic-devel Release.gpg
Get:38 https://repositories.intel.com/graphics/ubuntu bionic-devel/main amd64 Packages [4,164 B]
Reading package lists... Done
E: Failed to fetch http://ru.archive.ubuntu/dists/bionic/InRelease  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
E: The repository 'http://ru.archive.ubuntu bionic InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I'm already worried I'm gonna brick my laptop doing this, so I stopped.   I then thought it might make sense to point to another source repository so I enabled "deb-src http://us.archive.ubuntu.com/ubuntu/ bionic main restricted" in /etc/apt/sources.list.  (maybe this is doomed, but it seemed like a reasonable try.)  It didn't help.  The result was:
root@t570:~/OneAPI# apt build-dep linux linux-image-$(uname -r)
Picking 'linux-signed-hwe' as source package instead of 'linux-image-5.3.0-53-generic'
E: Unable to find a source package for linux-image-5.3.0-53-generic
So, I'm kinda stuck.  Anyone got some advice for me?  Is building a new i915 module really worth it?
ChithraJ_Intel
Hi Craig,
The issue that you observed while running the first command for "Adding source package repositories for your Ubuntu* version", seems to be an intermittent. Could you please try re-running the command and let us know whether the issue persists.
We are unable to reproduce the issue while running the second step(Install build dependencies). So, we are forwarding your case to engineering team and they will get back to you on this soon.
Egor_S_Intel1
Hi Craig,
Could you please try the following command:
sudo add-apt-repository -s "deb http://us.archive.ubuntu/ bionic main restricted"
CFR
New Contributor II
I tried the following thrice.  This is the result of the last try.
user@t570:~/OneAPI$ sudo add-apt-repository -s "deb http://us.archive.ubuntu/ bionic main restricted"
Hit:2 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:3 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
Ign:5 http://us.archive.ubuntu.com bionic InRelease
Err:6 http://us.archive.ubuntu.com bionic Release
  404  Not Found [IP: 91.189.91.38 80]
Get:7 http://us.archive.ubuntu bionic InRelease
Err:7 http://us.archive.ubuntu bionic InRelease
Hit:8 http://security.ubuntu.com/ubuntu bionic-security InRelease
Ign:9 https://repositories.intel.com/graphics/ubuntu bionic-devel InRelease
Hit:10 https://repositories.intel.com/graphics/ubuntu bionic-devel Release
Ign:11 https://repositories.intel.com/graphics/ubuntu bionic-devel Release.gpg
E: The repository 'http://us.archive.ubuntu.com bionic Release' does not have a Release file.
E: Failed to fetch http://us.archive.ubuntu/dists/bionic/InRelease  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
E: The repository 'http://us.archive.ubuntu bionic InRelease' is not signed.
Edit 1:
I think some of the errors above are due to artifacts of some of my attempts to add other repositories.  I _think_ I've got the repository stuff back to an original state, and here is the result of attempting what you asked:
user@t570:~/OneAPI/Bionic$ sudo add-apt-repository -s "deb http://us.archive.ubuntu/ bionic main restricted"
Hit:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
Get:5 http://us.archive.ubuntu bionic InRelease
Err:5 http://us.archive.ubuntu bionic InRelease
Hit:6 http://security.ubuntu.com/ubuntu bionic-security InRelease
Ign:7 https://repositories.intel.com/graphics/ubuntu bionic-devel InRelease
Hit:8 https://repositories.intel.com/graphics/ubuntu bionic-devel Release
Ign:9 https://repositories.intel.com/graphics/ubuntu bionic-devel Release.gpg
Hit:3 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:4 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:5 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
Get:6 http://us.archive.ubuntu bionic InRelease
Err:6 http://us.archive.ubuntu bionic InRelease
Get:3 http://us.archive.ubuntu bionic InRelease
Err:3 http://us.archive.ubuntu bionic InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
Egor_S_Intel1
Sorry, it is a typo in my previous answer. Could you please try the following command if the problem still exists:
sudo add-apt-repository -s "deb http://us.archive.ubuntu.com/ubuntu/ bionic main restricted"
MaheshB_Intel
As we have not heard back from you, we are considering that your issue has been resolved and we have answered all your queries. So we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only
Have a Good day!
Thanks & Regards
Mahesh
