Analyzers
5307 Discussions
data collected in command-line,how to view the result in GUI?
softarts
the data are collected via command-line:
./vtl show
VTune Performance Analyzer 9.1 for Linux*. FOR NON-COMMERCIAL USE ONLY build 102
Copyright (C) 2000-2008 Intel Corporation. All rights reserved.
a1__Activity1
r1___Tue Dec 16 17:35:41 2008 - Sampling Results [a0012330]
a2__Activity2
a3__Activity3
a4__Activity4
r1___Call Graph Results [localhost] - Thu Dec 18 10:37:42 2008
./vtl query -a a18
Duration: 20 sec
Start with data collection paused: no
Application/Module Profiles:
1. a
Application to Launch:
Filename: /home/ruizhou/ms/a.out
Command line arguments: -s
System on which to launch application:
2. Modules of Interest
Modules of Interest:
1. /home/ruizhou/ms/a.out
Data Collectors:
1. Call Graph
Collector type: Call Graph
Master: no
Enabled: yes
Associated with the following Application/Module Profiles:
1. a
Options:
Folder with call graph configuration files (*.ini) for this Activity: /root/VTune/Projects/vtune/cg1A441394/
how to open these result of activity in GUI mode?
Peter_W_Intel
1) You can use vtl in command line to display results - for example
vtl view a4::r1 -critical-path
2) If you log on as vnc client (X-Window), you can use -
vtl view a4::r1 -gui
3) You can pack current projetcs, and import it to vtlec then display results (if you have X-Window)
vtl pack vxp_file_name
Regards, Peter
David_A_Intel1
Also see 'man vtl' or 'man sampling' or 'man callgraph' for more information.
And, if man isn't working for you, there is always 'vtl -help'.
Mr.Anderson
