Analyzers
5271 Discussions
error on startup - File Not Found - sunrpc
komradebob
When I try to start up the gsexample2a from the turorial, we get a popup 'File Not Found' for sunrpc.
A) is it important?
b) other than 'skip always' is there a way to make this go away?
file not found
Peter_W_Intel
The tool has to find the location of binary (module) - maybe there are many versions of this module.
That is only for first time association, the user will NOT be asked later.
The user also can specify Directories, by using Preferences -> VTune Performance Tools -> Directories -> Add items in Directories for finding Binary/Source/Symbol files.
Regards, peter
komradebob
that worked great. thanks.
