Analyzers
5285 Discussions
some of my functions are not in the call graph
morca
I used vtune to create a call graph for my application. As you can see in the picture, some of the functions called in the main (source code in the right window) are not shown in the call graph (left window) and also some of things that are listed in the call graph are not in the main (right window).
vtune window
Thanks for any sugestion.
Peter_W_Intel
That is great! Call graph can work on your side.
A1. Call graph can work with applications built with Release mode, but shouldaddcompiler option "/Zi", linker options "/DEBUG", "/Fixed:no". Fordisabling in-line functions, read this article
A2. Please refer to this article
Regards, Peter
Peter_W_Intel
I can't seethis picture, please verify.
If some of functions called by main(), but not shown in call graph report window - probably
1) Your called functions are "inline", please use disabling optimization to rebuild and retry.
2) Your called functionwere not executed.
Regards, Peter
morca
Here is the image location: http://www.imagechicken.com/uploads/1275389830077720300.png
Please note that in the main function I have "cipher()" but it is not listed in the call graph window.
I also have to say that the code is an AES example which is located at http://www.hoozi.com/post/829n1/advanced-encryption-standard-aes-implementation-in-c-c-with-comments-part-1-encryption
As you can see, the function is not inlined and I checked with a simple printf() to check that the function is actually running.
morca
You were right. My first run was in release mode and as you said I rebuild run again in debug mode. It is now working.
Two more question:
1- Debug mode is not of my interest in performance analysis. How can I disable the inlining in release mode?
2- When I run the counter monitor activity, I get this:
"No data to display for selected couters. Either no counters have been selected or there is no data available for the selected counters. Try selecting additional counters or run the activity again to collect new data.
I tried running the counter monitor again as it is stated but get the same message.
Considering this "Either no counters have been selected or there is no data available for the selected counters.", where should I select counters?
Peter_W_Intel
Regards, Peter
morca
1- I am using VS2008 but the article is for intel compiler. Anyway, I set three options as you mentions: "/Zi", "/DEBUG" and "/Fixed:no". But when I check the inlining optimization option I only have these options:
default
Only __inline (/Ob1)
Any suitable (/Ob2)
I tested all three but in the call graph still there is no "cipher()".
2- The article is for windows 2000. Many registry keys that are listed are not available in my XP. But I found this artivle useful http://software.intel.com/en-us/articles/intel-vtune-performance-analyzer-for-windows-counter-monitor-issues/
Peter_W_Intel
I have no idea for Microsoft* C/C++ compiler to disable inline with using optimization options.
For using counter monitor - try Perfmon.exe first.
morca
Thanks for your advice. I found this article that explains the optimization switches in VS. Hope this will be usefull for others too
Developing optimized code with microsoft visual c++6.0
http://msdn.microsoft.com/en-us/library/aa260969%28VS.60%29.aspx
