Analyzers
Support for Analyzers (Intel VTune™ Profiler, Intel Advisor, Intel Inspector)
failed to finalize the result
rohit_t_
hello everyone !
while doing hotspot analysis ,concurrency,locks and waits  etc . I am getting "failed to finalize the result ,the result you are opening is empty" error ....
while for some other analysis like lightweight hotspot,memory acces its working fine ,giving results.
what may be the plausible reason behind it and how to resolve it ...
please help !
Peter_W_Intel
What is output after doing "amplxe-cl -collect hotspots -r /tmp/r000hs -- /bin/ls" ?
rohit_t_
hey peter,
please guide me in which directory i should run this command whether in this   C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\bin32\ or any where else?
my result file is stored in this address C:\Users\rohtiwar\Documents\Amplifier\Projects\try15\r000hs\
i am using windows 7 64-bit machine...
when i ran this command
C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\bin32>amplxe-cl -collect hotspots -r C:/Users/rohtiwar/Documents/Amplifier/Projects/try15/r000hs -- /bin32/ ls
this Error occured : Cannot find application file "/bin32/ls".
or if my command was wrong please tell me the correct one
thanks
rohit_t_
hey peter,
thanks
Peter_W_Intel
Sorry that I don't know you work on Windows 7.
Probably you shouldn't work on "C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\bin32" directory for Windows 7. Try below:
cd c:\temp
C:\temp>"\Program Files (x86)\intel\VTune Amplifier XE\amplxe-vars.bat"
Copyright (C) 2009-2012 Intel Corporation. All rights reserved.
Intel(R) VTune(TM) Amplifier XE 2013 (build 261256)
C:\temp>amplxe-cl -collect hotspots -- explorer
