Analyzers
5307 Discussions
how to generate a timeline report with the right column-by=x
shuoli01
I am trying to generate time view from the existing sampling r000hpc by using command line.
% vtune -report timeline -r r000hpc
 vtune: Using result path `/root/r000hpc'
vtune: Executing actions 75 % Generating a report Error: the required argument "column-by" is missing. Please provide it in the form: "-report-knob column-by=<value>"
vtune: Executing actions 100 % done
vtune: Error: 0x40000028 (Reporter error)
vtune -report timeline -report-knob column-by=10 -r r000hpc
Invalid column-by query (10) is provided. The query is either unknown or not applicable to the current result.
vtune: Error: 0x40000023 (User input error)
My question is what's the column-by number, how to set it to create a timeline report?
Cheers
DiyaN_Intel
Could you please share the following details which will help us to investigate further-
1. Sample reproducer code and the result file generated.
2. Intel VTune version.
3. Exact steps and the commands used.
4. Operating system, kernel, and processor details.
Diya
DiyaN_Intel
Hi ,
We were able to reproduce the issue from our end.
The following is analysis type / data collector: valid column-by values for HPC Performance Characterization Analysis on TGL NUC with Ubuntu 20.04.6 LTS
Analysis Type
Columns Used
HPC SEP
CPI, CPUTime, InstructionsRetired, Task, TaskTime, TaskType, Vectorization
HPC VTSS
For example, you have to give the below CLI command and it will show the results
vtune -report timeline -r r000hpc -report-knob column-by=CPUTime
Note: Task and TaskType are only valid with ITT API user tasks
If you face any issues, please connect back to us.
If this resolves your issue, make sure to accept this as a solution.
This would help others with similar issues. Thank you!
Diya
DiyaN_Intel
Good day to you.
We have not heard back from you.
Is your issue resolved with the above solution?
Thanks and Regards,
Diya
DiyaN_Intel
Good day to you.
We assume that your issue is resolved.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
Diya
