Analyzers
5273 Discussions
i can't use rmtsvr. i think it may be the result of different version of compiler
nengnengwin
we use vtune analyze to our target(pxa255+linux2.4.19).In the past ,we use arm-linux-gcc 2.95.3 to build our kernel and modules.The rmtsvr and vtlxsc you given to me is also build with 2.95.3 and thy worked well. But recently ,we have changed our arm-linux-gcc to 3.3.2, i rebuild the vtune_drv.o . When i run rmtsvr on my target,is shows :
#/root>./rmtsvr
Copyright (C) 2001-2003 Intel Corporation. All rights reserved.
VTune Performance Analyzer Update for Intel XScale Techonlogy, PXA Linux*
Version: 7.1.6.215
Server is Starting
Waiting for connection ...
but when i connect the target on host(PC) with XscVTuneHostDC.exe , the host shows connection failed and there is an error on target as follows:
Connection Established
pc : [<00024cec>] lr : [<00027a5c>] Not tainted
sp : bf7ff4c4 ip : bf7ff4f4 fp : bf7ff4f0
r10: 400383d4 r9 : 00018b30 r8 : bffff9fc
r7 : 00001000 r6 : bf7ff588 r5 : 7265632d r4 : bf7ff554
r3 : bf7ff554 r2 : bf7ff588 r1 : 7265632d r0 : bf7ff554
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user
Control: 397F Table: A3CDC000 DAC: 00000015
Segmentation fault
Would you mind building the rmtsvr and vtlxsc with arm-linux-gcc 3.3.2 for us ? I think it maybe the fault of compiler . Is there any other reasons for the error?
Looking for your early reply! thanks a lot!
David_A_Intel1
Hi!
I'm really sorry that I can't answer that question. It would probably be better if you submitted this issue at Intel Premier Support. That will allow the team that is responsible for the XScale technology remote collector to investigate the problem and assist you.
If you do not have an account at Premier Support, simply register for an eval at http://www.intel.com/software/products/global/eval.htm. You do not have to actually download or install the software (you already have it, anyway!), but the process will create an account for you at Premier Support.
Message Edited by DaveA on 10-04-2005 09:48 AM
nengnengwin
i can not connect to premier.intel.com when i putin myid and password .can you tell me an e-mailfrom which i can get some support .thanks a lot!
David_A_Intel1
I'm sorry, but Premier Support is our only support mechanism.
Please try your email address as the id and then your password. If you can't remember your password, or can't log in, please send an email to quad.support@intel.com asking that your password be reset.
