Analyzers
5284 Discussions
iGPU and NPU details not showing up in Application Performance Snapshot (APS) Report
Rajeev_A_Intel
I am profiling a workload to run on CPU, iGPU, and NPU using OpenVINO framework. I am able to see details like PCU, Memory Stalls, DRAM Stalls, DRAM Bandwidth, Vectorization, Memory Footprint, etc.
I am looking for iGPU and NPU usage as part of profiling through APS. System is Ubuntu 22.04.
Linux sdp 6.8.0-52-generic #53~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Wed Jan 15 19:18:46 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
yuzhang3_intel
So far VTune doesn't support NPU profiling on Linux.
If you can run the OV workload on Windows, you can try the XPU analysis type to analyze and correlate CPU, iGPU, and VPU in the timeline.
Rajeev_A_Intel
Does it support iGPU analysis on Ubuntu? I am using Linux and not Windows. So, I will have to assume this to be a short coming of the tool.
yuzhang3_intel
Yes, you can use gpu-hotspots and gpu-offload analysis types to profile GPU.
VTune supports CPU/GPU profiling on both Windows and Linux, and NPU profiling on Windows only.
Rajeev_A_Intel
I typically use aps -r=./vtune python temp.py as the command. It is not providing the GPU details.
I need to use vtune -collect gpu-offload python temp.py ?
yuzhang3_intel
You can refer to the content for GPU profiling in the user guide:
https://www.intel.com/content/www/us/en/docs/vtune-profiler/user-guide/2025-0/accelerators-group.html
For GPU OV profiling, you can refer to the article in Cookbook:
https://www.intel.com/content/www/us/en/docs/vtune-profiler/cookbook/2025-0/profiling-llms.html
