I am trying to profile my workload on LNL and MTL. There are different CPU cores in such machines. It includes P-Cores, E-Cores Ultra Efficient Cores, iGPU, & NPU. I am not sure if it is supported. System Details.
Linux sdp 5.15.0-133-generic #144-Ubuntu SMP Fri Feb 7 20:47:38 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
PRETTY_NAME="Ubuntu 22.04.5 LTS"
NAME="Ubuntu"
VERSION_ID="22.04"
VERSION="22.04.5 LTS (Jammy Jellyfish)"
VERSION_CODENAME=jammy
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=jammy
The error I get is as follows.
vtune: Warning: Memory bandwidth collection requires the sampling driver to be enabled on the system. Disable the "Analyze memory bandwidth" knob to proceed with the analysis or install the sampling driver on the system. See the Sampling Drivers help topic for more details. Note that memory bandwidth collection is not possible if you are profiling inside a virtualized environment.
vtune: Error: Current OS kernel does not support driverless collection on hybrid CPUs. Consider loading the VTune Profiler sampling driver using root credentials or updating the OS kernel.
aps Error: Cannot run the collection.
You need to build and install VTune driver first:
