Analyzers
5307 Discussions
integrating performance analyser with an automating tool.
vamsidhar_s_
Hi All,
I'm trying to run intel v tune performance analyser with jenkins. To do so i need the window batch file to set up the environment. can someone tell me where will i find the batch file of it.
Peter_W_Intel
You might set up environmnet in your batch file, run amplxe-vars.bat under C:\Program Files (x86)\Intel\VTune Amplifier XE 2013, so you can run amplxe-cl to collect data & generate the report.
vamsidhar_s_
Hi Peter, Thanks for the help. I tried executing these commands through a batch file. amplxe-vars.bat vtl query -project The first line got executed but not the second. Also can u tell me how to run amplxe-cl to collect the data.
Peter_W_Intel
You should see about using amplxe-cl in online helper. I wrote a simple blog [html]http://software.intel.com/zh-cn/blogs/2010/11/10/amplxe-cl/[/html] to show examples of using command line (Sorry it is in Chinese, but you can find many useful examples in 1-2-3-4)
