Analyzers
5340 Discussions
Message when program running under Intel Advisor xe
newport_j
When I was running my program on Intel Advsir xe 2013, during the running process I got the follwinw message:
A symbol file is not found. The call stack passing through '[vdso]' module may be incorrect
I checked and recompiled my program with the -g option because I thought that was the
symbol file not found and thus the source of the error. . I still got the error anyway. What am I doing wrong and how can I fix it?
Thanks in advance.
Newport_j
Ravi_V_Intel
Hello Newport_j. You can safely ignore the message/warning. The following article provides greater detail on this topic. I am assuming that you encountered this warning when running either the Survey or the Suitability. Please alert me if this is not the case. http://software.intel.com/en-us/articles/vtune-amplifier-xe-warning-symbol-file-is-not-found Hope it helps. Intel Developer Support
