Analyzers
5279 Discussions
intel VTune -- weird results
mrkf100
Hi everyone!
I wrote a C++ program for computing the elements of the logistic map and profiled it by using intel VTune Profiler but in the results there is a surprising thing: in the row of 'Cycles of 3+ Port Utilized' there is 55.6 % but below it in every row there is 0.0 %. What does it mean? Where could that 55.6 % disappear? (I'm very beginner in profiling codes.)Logisticmap_vect_question.PNG
The exact program I profiled is here:
#include <iostream>
#include <time.h> //clock!!
#include <fstream>
#include <vector>
#include <stdio.h>
#define MAX_VECTOR_SIZE 256
#include <vectorclass.h>
#include <cstdlib>
#include <malloc.h>
using namespace std;
int main()
	// Allocated on STACK
	const int Resolution = 4 * 8 * 3125; // Dividable by 4
	const int Transients = 512;
	const int SavedPoints = 128;
	const int LoopUnrollFactor = 4 * 8;
	//double r[Resolution];
	//double x[Resolution];
	// Allocated on HEAP
	double* r = (double*)_aligned_malloc(Resolution * sizeof(double),64);
	double* x = (double*)_aligned_malloc(Resolution * sizeof(double),64);
	//double* r = new double[Resolution];
	//double* x = new double[Resolution];
	// Initialisation
	double dr = 4.0 / (Resolution - 1.0); // Only 1 type conversion!
	r[0] = 0.0;
	x[0] = 0.5;
	for (int i = 1; i < Resolution; i++)
		r[i] = r[i - 1] + dr;
		x[i] = 0.5;
	// Transient iterations
	clock_t SimulationStart = clock();
	Vec4d xact[8];
	Vec4d ract[8];
	for (int i = 0; i < Resolution; i += LoopUnrollFactor)
		#pragma unroll
		for (int k = 0; k < 8; k++)
			xact[k].load_a(x + i + k * 4); // Loading states from alligned memory
			ract[k].load_a(r + i + k * 4); // Loading parameters from alligned memory
		for (int j = 0; j < Transients; j++)
			#pragma unroll
				xact[k] = ract[k] * xact[k] * (1.0 - xact[k]);
		#pragma unroll
			xact[k].store_a(x + i + k * 4); // Storing states from alligned memory
			ract[k].store_a(r + i + k * 4); // Storing parameters from alligned memory
	clock_t SimulationEnd = clock();
	cout << "Simulation time: " << 1000.0*(SimulationEnd - SimulationStart) / CLOCKS_PER_SEC << "ms" << endl << endl;
	// Converged iterations and save to file
	/*ofstream DataFile;
	DataFile.open("LogisticMap.txt");
	int Width = 18;
	DataFile.precision(10);
	DataFile.flags(ios::scientific);
	for (int i = 0; i < Resolution; i++)
		for (int j = 0; j < SavedPoints; j++)
			x[i] = r[i] * x[i] * (1.0 - x[i]);
			DataFile.width(Width); DataFile << r[i]; //Don't place here any commas, because dlmread won't work in MATLAB!!!
			DataFile.width(Width); DataFile << x[i];
			DataFile << '\n';
	DataFile.close();*/
	return 0;
Thanks for your answer in advance.
Kirill_U_Intel
Hi.
Is it possible to increase workload time
0.038 sec is too small to build correct microarchitecture metrics at all.
They could be incorrect such in your case
Kirill
JananiC_Intel
Thanks for posting in Intel forums.
We will try from our end and let you know.
Janani Chandran
Kirill_U_Intel
Hi.
Kirill
JananiC_Intel
Is your issue resolved? Please let us know if the issue still persists.
Janani Chandran
mrkf100
Hi!
Thank you, it helped a lot! After increasing the number of Resolution the error did'nt appear.
mrkf100
JananiC_Intel
Thanks for the confirmation. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Janani Chandran
