When I typed make in the new nqueens_Advisor directory I got the serial and
annotated executables, but not annything esle. I got errors:
TBBROOT environment varaibles not defined. Required to build TBB sample.
icpc -m64 nqueens_cilk.cpp -0 4 queens_cilk -)2 -g lcilkarts
make: icpc: command not found
make: *** [4_nqeens_cilk] Error 127
Now I do not have Intel Threaded Building Blocks installed and, but I I do have
Intel Cilk installed, but it is on a different machine.
So how do I recover from this errors?
Any help appreciated. Thanks in advance.
Newport_j
Hello newport_j,
Here is some help regarding TBBROOT (from the Release Notes which you can find here: ):
Intel Advisor XE samples work with the Intel TBB by using the environment variable TBBROOT. Intel TBB is included with the Intel® Composer XE and is available from http://software.intel.com/en-us/intel-tbb/. To build the Intel TBB applications, you will need to define the TBBROOT environment variable.
It also appears to me that you do not have the Intel(R) Composer XE installed. I recommend you to download the Intel(R) Parallel Studio XE 2013 suite or the Intel(R) C++ Studio XE 2013 suite so that you can get all the necessary components in one shot and install them. Be forwarned that the suite installer is quite large in download size and may take a while.
Please let me know if I can help further.
Thank you.
Intel Developer Support
![](/skins/images/06022F5BB6D2F28C8F102671A0F06E85/responsive_peak/images/icon_anonymous_message.png)
Topic Options
