Analyzers
missing libs when running system_analyzer
BenKo
system_analyzer seems like an interesting tool to try (introduced in 2019 u2, i'm using 2019 u3)
however i'm getting error when trying to run it on CentOS 7
ldd /opt/intel/vtune_amplifier/system_analyzer/target/gpa_router
/opt/intel/vtune_amplifier/system_analyzer/target/gpa_router: /lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/intel/vtune_amplifier/system_analyzer/target/gpa_router)
/opt/intel/vtune_amplifier/system_analyzer/target/gpa_router: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /opt/intel/vtune_amplifier/system_analyzer/target/gpa_router)
/opt/intel/vtune_amplifier/system_analyzer/target/gpa_router: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /opt/intel/vtune_amplifier/system_analyzer/target/gpa_router)
/opt/intel/vtune_amplifier/system_analyzer/target/gpa_router: /lib64/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /opt/intel/vtune_amplifier/system_analyzer/target/gpa_router)
thanks
Stas-Neverov-Intel
Hi BenKo,
System Analyzer is part of the Intel Graphics Performance Analyzers (GPA). System requirements for GPA could be found here - https://software.intel.com/en-us/gpa/documentation/specifications. The only Linux distro officially supported is Ubuntu 16+.
-Stas
BenKo
Hi Stas,
Thank you. Based on the error I suspected the release might be trageting Ubuntu.
My interest has been prompted by this page
https://software.intel.com/en-us/vtune-amplifier-cookbook-real-time-monitoring-with-system-analyzer
which introduces System Analyzer as a preview feature of VTune (it also mentions it is part of the Intel Graphics Performance Analyzers).
The recipe describes how the System Analyzer can be used to monitor a target system in real-time to identify whether it is CPU, GPU, memory, disk, or network bound. It talks about Linux and never mentions Ubuntu apart from See Also.
Perhaps the recipe needs an addentum.
Elena_F_Intel
Thank you for the feedback. The Cookbook article is updated.
