Analyzers
no gui under linux?
linfa
I installed inspector evaluation version on my Linux machine ( CentOS release 5.4 (Final) ). I am trying to follow the turorial
" Type ./inspxe-gui to open the standalone Intel Inspector XE client interface and display a window similar to the following: "
But I could not find ./inspxe-gui. Do I miss something during the installation? Here is more info. Thanks.
[linfa@foyt bin64]$ pwd
/opt/intel/inspector_xe_2011/bin64
[linfa@foyt bin64]$ ll
total 7416
-rwxr-xr-x 1 root root 291890 Feb 3 08:18 inspxe-cl
-rwxr-xr-x 1 root root 355675 Feb 3 08:14 inspxe-feedback
-rwxr-xr-x 1 root root 106386 Feb 3 08:17 inspxe-runmc
-rwxr-xr-x 1 root root 153191 Feb 3 08:18 inspxe-runtc
-rw-r--r-- 1 root root 1333 Feb 3 08:01 leakdetectiontool.exclude
-rwxr-xr-x 1 root root 1895 Feb 3 08:00 pin
-rwxr-xr-x 1 root root 6642256 Feb 3 08:09 pinbin
[linfa@foyt bin64]$ ./inspxe-cl -version
Intel Inspector XE 2011 Update 2 (build 134657) Command Line tool
Copyright (C) 2009-2011 Intel Corporation. All rights reserved.
Peter_W_Intel
I don't know if you used latest product's update from - https://registrationcenter.intel.com/RegCenter/Download.aspx?productid=1392&sn=
During installing the product, you should see "3. Change components to install" - default is "All", no change. Then you will see -
Installing Inspector XE Command line interface component... done
Installing Inspector XE Graphical user interface component... done
By the way,if you want to install the software for use by any user, you must do this as the root user.
[root@NHM02 bin64]# ./inspxe-cl -version
Intel Inspector XE 2011 Update 1 (build 131372) Command Line tool
Copyright (C) 2009-2010 Intel Corporation. All rights reserved.
[root@NHM02 bin64]# ls -l
total 8484
-rwxrwxr-x 1 root root 278593 Jan 10 17:31 crashreport
-rwxrwxr-x 1 root root 301229 Jan 10 17:18 inspxe-cl
-rwxrwxr-x 1 root root 362285 Jan 10 17:16 inspxe-feedback
-rwxrwxr-x 1 root root 777366 Jan 10 17:31 inspxe-gui
-rwxrwxr-x 1 root root 111117 Jan 10 17:18 inspxe-runmc
-rwxrwxr-x 1 root root 153877 Jan 10 17:18 inspxe-runtc
-rw-rw-r-- 1 root root 1333 Jan 10 17:01 leakdetectiontool.exclude
-rwxrwxr-x 1 root root 1895 Jan 10 17:01 pin
-rwxr-xr-x 1 root root 6642256 Jan 10 17:14 pinbin
Please downloadlatest product package, uninstall/reinstall the product.
Regards, Peter
linfa
Hi Peter,
Thanks. I was hitting "enter" key too fast during the installation
Linfa
