Analyzers
5342 Discussions
oneAPI offload advisor: loop instance limitation warning
lm1909
I am using collect.py from the oneAPI beta Offload Advisor and am receiving the warning
advixe: Warning: Loop instance limitation doesn't support source annotations.
after the collection started. I can't find any information about this warning online - what does it mean, is it relevant, and if yes, how can I fix it?
dpetrov
Hi @lm1909 ! This message is sort of internal diagnostics. In short, it should not affect performance modelling flow.
Few more details: this message is emitted by dependencies analysis which supports for source annotations to mark loop body. Source annotations are not compatible with one another feature that allows to reduce profiling overhead and is used in performance modelling flow. So if you have loop body marked up with source annotations, overhead will be bigger than for case w/o source annotations.
AbhishekD_Intel
As this thread is not related to this forum, we are moving this thread to the appropriate forum.
Thank you.
dpetrov
