Analyzers
performance test start
joydevg
We are started, as per documentation for performance testing our Application through VTune(Intel) version "w_vt_p_9.0.010.exe".
but we are facing some problem, After doing few steps..there is a pop-up menu are comming
Error:-is the following
"Terminate Application Forcible?
The software is trying to terminate the following
application that is started:
E:Intel VTune AnalyserjarCourseDesigner.exe.
Would you like to terminate the application forcible?YES/NO??"
If Anybody Knows pls. help me.
joydev
assiatoune
hi,
this is due to that you did not well confgure your activty,
because it has a default duration, so if this duration is less than your application one, so it will try to stop it.
so go to the activity properties and then configure it but putting a duration which is >= to your application one.
hope this will help you.
assia
