Analyzers
5296 Discussions
process crashes when running with VTune
kooijman__jacob
I am using VTune 2018 update 1 and when running my application via VTune it crashes immediately at startup. I also tried executing vtune via command line: amplxe-cl -c hotspots application.exe
I also tried attaching VTune to a running process and that goes fine until application shutdown, than VTune seems to think its a crash and loses all profiling information. If i collect profiling information before shutdown the results look good.
Its a 32 bit process  on windows 10 (delphi) which run's C++ code.
Any tips for investigation or possible causes?
zhang__chen
For me, the hotspot works fine but HPC analysis often (90% cases) cause the program to crash. Error messages are like access violation with some PC numbers. No idea about how to deal with it.
