Analyzers
5247 Discussions
"unhandled exception" inside Inspector 2018 Update 3 (Windows)
AndrewC
New Contributor III
When testing our code for data races etc, it is failing inside Inspector 2018 Update 3 with the error below. No other errors are reported.
The code runs fine outside of Inspector.
In the sourcethe statement at which the exception occurs is a "omp parallel for" construct.
ID        Type    Sources    Modules    State
P1        Unhandled application exception    kmp_itt.inl    libiomp5md.dll    New
Description    Source    Function    Module    Variable
Exception    kmp_itt.inl:332    __kmp_join_barrier    libiomp5md.dll
    >libiomp5md.dll!__kmp_join_barrier - kmp_itt.inl:332
I am at a loss as to how to proceed as it is not clear if this is Inspector issue or an issue in our code.
