Analyzers
5292 Discussions
socwatch2_15 module is not loaded correctly when using kernel 6.8.x - vtune/oneapi 2024.1 version
IonutNechita
I notice this when trying to use VTune 2024.1 version:
Building socwatch driver ...
Building drivers for Linux target
-n switch is deprecated. Now it does not have any effect.
/lib/modules/6.8.2-lowlatency1/build will be used as the kernel build directory
Removing previously built driver and scripts from /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/drivers
-c /bin/gcc -l -k /lib/modules/6.8.2-lowlatency1/build will be used to build the SoCWatch driver
************ Building socwatch2_15-x32_64-6.8.2-lowlatency1smp.ko driver ************
Using C compiler = /bin/gcc
Using kernel build dir = /lib/modules/6.8.2-lowlatency1/build
No module symvers file found
Using common inc dir = /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/../common/include
"/lib/modules/6.8.2-lowlatency1/build/include/linux/cpufreq.h" exists!
Using file name sw_driver
Make args = KERNEL_SRC_DIR=/lib/modules/6.8.2-lowlatency1/build CPUFREQ_FIX_BACKPORTED=1 DO_DEBUG_BUILD=0 DO_PROFILING=0 COMMON_INC_DIR=/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/../common/include MODULE_SYMVERS_FILE= FILE_NAME=sw_driver
make[1]: Entering directory '/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver'
make -C /lib/modules/6.8.2-lowlatency1/build M=/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver clean
make[2]: Entering directory '/usr/src/linux-headers-6.8.2-lowlatency1'
make[2]: Leaving directory '/usr/src/linux-headers-6.8.2-lowlatency1'
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver'
DO_DRIVER_PROFILING=0
INCDIR_1=/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/../common/include
make -C /lib/modules/6.8.2-lowlatency1/build M=/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver modules PWD=/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_driver.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_hardware_io.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_output_buffer.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_tracepoint_handlers.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_collector.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_mem.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_internal.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_file_ops.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_ops_provider.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_trace_notifier_provider.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_reader.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_telem.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_pmt.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_counter_list.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_pci.o
  LD [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/socwatch2_15.o
  MODPOST /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/Module.symvers
ERROR: modpost: module socwatch2_15 uses symbol pmt_telem_get_next_endpoint from namespace INTEL_PMT_TELEMETRY, but does not import it.
ERROR: modpost: module socwatch2_15 uses symbol pmt_telem_register_endpoint from namespace INTEL_PMT_TELEMETRY, but does not import it.
ERROR: modpost: module socwatch2_15 uses symbol pmt_telem_unregister_endpoint from namespace INTEL_PMT_TELEMETRY, but does not import it.
ERROR: modpost: module socwatch2_15 uses symbol pmt_telem_get_endpoint_info from namespace INTEL_PMT_TELEMETRY, but does not import it.
ERROR: modpost: module socwatch2_15 uses symbol pmt_telem_read from namespace INTEL_PMT_TELEMETRY, but does not import it.
make[4]: *** [scripts/Makefile.modpost:217: /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/Module.symvers] Error 1
make[3]: *** [/usr/src/linux-headers-6.8.2-lowlatency1/Makefile:2084: modpost] Error 2
make[2]: *** [Makefile:257: __sub-make] Error 2
make[1]: *** [Makefile:114: default] Error 2
ERROR: Failed to build socwatch2_15-x32_64-6.8.2-lowlatency1smp.ko driver
****** Errors occurred. Please check /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/driver_build_errors.txt for errors and the stderr/stdout for more information ******
yuzhang3_intel
Which platform? Kernel version is 6.8.2?
IonutNechita
Ubuntu 22.04 OS with kernel 6.8.2 and GCC 11.4.0 using TGL board.
yuzhang3_intel
Let me check and update later. If you don't measure power, VTune should work.
Jennifer_D_Intel
I can also validate, but I don't believe Linux kernel 6.x is supported yet for VTune.
IonutNechita
Hi @Jennifer_D_Intel ,
Ok. Understood. Maybe in feature will be ready for Ubuntu 24.04 LTS.
zamazan4ik
Are there public-available plans or something like that about Linux kernel 6.x support for VTune? I also met this limitation. We use 6.x kernels since it consist of useful techs for us.
Jennifer_D_Intel
I will follow up with the development team on the current status of kernel 6.x support. It looks like there are some issues with 6.8, but earlier than that should work.
IonutNechita
Thank you for this resolution.
Will be wait to have one VTune version with socwatch module correctly inserted in 6.8.x kernel.
Good day.
Cathy
Is there any update on this? I'm on a similar kernel version and meeting similar issue. I'm on a Meteor Lake Ubuntu 22.04 with kernel 6.8 (have to upgrade kernel to beyond 6.7 to have all stabilized MTL drivers).
thanks
Cathy
Cathy
It seems that adding following line near MODULE_IMPORT_NS in socwatch/socwatch_driver/src/sw_driver.c will do the fix.
#ifdef MODULE_IMPORT_NS
MODULE_IMPORT_NS(INTEL_PMT);
MODULE_IMPORT_NS(INTEL_PMT_TELEMETRY);  //add this line
#endif
IonutNechita
Hello @Cathy ,
Will try this week to check your change.
But i not have feedback from OneAPI and VTune Team for this issue in this period.
When i check your change, will be write a one note with my feedback.
Thank you Cathy for this.
A good day.
BR,
Ionut
IonutNechita
Hello @Cathy ,
I tried today with your change and is working now.
journalctl -b --no-pager | grep sep5-load.sh
May 20 15:06:11 my-machine sep5-load.sh[810]: Loading the sep5 driver:
May 20 15:06:11 my-machine sep5-load.sh[820]: PYTHON is set to python
May 20 15:06:11 my-machine sep5-load.sh[820]: Detecting Secure Boot status...
May 20 15:06:11 my-machine sep5-load.sh[820]: Secure Boot is disabled
May 20 15:06:11 my-machine sep5-load.sh[820]: ---------------------    Loading PAX driver    ---------------------
May 20 15:06:11 my-machine sep5-load.sh[1086]: Detecting Secure Boot status...
May 20 15:06:11 my-machine sep5-load.sh[1086]: Secure Boot is disabled
May 20 15:06:11 my-machine sep5-load.sh[1086]: Checking for PMU arbitration service (PAX) ... not detected.
May 20 15:06:11 my-machine sep5-load.sh[1086]: Attempting to start PAX service ...
May 20 15:06:11 my-machine sep5-load.sh[1086]: Executing: insmod ./pax/pax-x32_64-6.9.0-x64v2-lowlatency1smp.ko
May 20 15:06:12 my-machine sep5-load.sh[1086]: Setting group ownership of devices to group "vtune" ... done.
May 20 15:06:12 my-machine sep5-load.sh[1086]: Setting file permissions on devices to "660" ... done.
May 20 15:06:12 my-machine sep5-load.sh[1086]: The pax driver has been successfully loaded.
May 20 15:06:12 my-machine sep5-load.sh[820]: ---------------------  Loading SOCPERF driver  ---------------------
May 20 15:06:12 my-machine sep5-load.sh[1454]: Detecting Secure Boot status...
May 20 15:06:12 my-machine sep5-load.sh[1454]: Secure Boot is disabled
May 20 15:06:12 my-machine sep5-load.sh[1454]: Checking for socperf driver ... not detected.
May 20 15:06:12 my-machine sep5-load.sh[1454]: Attempting to start socperf service ...
May 20 15:06:12 my-machine sep5-load.sh[1454]: Executing: insmod ./socperf/src/socperf3-x32_64-6.9.0-x64v2-lowlatency1smp.ko
May 20 15:06:13 my-machine sep5-load.sh[1454]: Setting group ownership of devices to group "vtune" ... done.
May 20 15:06:13 my-machine sep5-load.sh[1454]: Setting file permissions on devices to "660" ... done.
May 20 15:06:13 my-machine sep5-load.sh[1454]: The socperf3 driver has been successfully loaded.
May 20 15:06:13 my-machine sep5-load.sh[820]: ---------------------    Loading SEP driver    ---------------------
May 20 15:06:13 my-machine sep5-load.sh[820]: Executing: insmod ./sep5-x32_64-6.9.0-x64v2-lowlatency1smp.ko sym_lookup_func_addr="ffffffffa480ff30"
May 20 15:06:14 my-machine sep5-load.sh[820]: Setting group ownership of devices to group "vtune" ... done.
May 20 15:06:14 my-machine sep5-load.sh[820]: Setting file permissions on devices to "660" ... done.
May 20 15:06:14 my-machine sep5-load.sh[820]: The sep5 driver has been successfully loaded.
May 20 15:06:14 my-machine sep5-load.sh[820]: ---------------------  Loading VTSSPP driver  ---------------------
May 20 15:06:14 my-machine sep5-load.sh[820]: Checking for vtsspp driver ... not detected.
May 20 15:06:15 my-machine sep5-load.sh[2035]: Executing: insmod ./vtsspp/vtsspp-x32_64-6.9.0-x64v2-lowlatency1smp.ko gid=1001 mode=0660 ksyms="ffffffffa480ff30"
May 20 15:06:15 my-machine sep5-load.sh[2035]: The vtsspp driver has been successfully loaded.
May 20 15:06:15 my-machine sep5-load.sh[820]: --------------------- Loading SOCWATCH driver ---------------------
May 20 15:06:15 my-machine sep5-load.sh[820]: Checking for socwatch driver ... not detected.
May 20 15:06:15 my-machine sep5-load.sh[2062]: Executing: insmod ./socwatch/drivers/socwatch2_15-x32_64-6.9.0-x64v2-lowlatency1smp.ko
May 20 15:06:16 my-machine sep5-load.sh[2062]: Setting group ownership of device file to group "vtune" ... done.
May 20 15:06:16 my-machine sep5-load.sh[2062]: Setting file permissions of device file to "660" ... done.
May 20 15:06:16 my-machine sep5-load.sh[2062]: The socwatch2_15-x32_64-6.9.0-x64v2-lowlatency1smp driver has been successfully loaded.
May 20 15:06:16 my-machine sep5-load.sh[2062]: NOTE:
May 20 15:06:16 my-machine sep5-load.sh[2062]: The driver is accessible only to users under the group 'vtune'.
May 20 15:06:16 my-machine sep5-load.sh[2062]: Please add the users to the group 'vtune' to use the tool.
May 20 15:06:16 my-machine sep5-load.sh[2062]: To change driver access group, reinstall the driver using -g <desired_group> option.
May 20 15:06:16 my-machine sep5-load.sh[820]: NOTE:
May 20 15:06:16 my-machine sep5-load.sh[820]: The driver is accessible only to users under the group vtune.
May 20 15:06:16 my-machine sep5-load.sh[820]: Please add the users to the group vtune to use the tool.
May 20 15:06:16 my-machine sep5-load.sh[820]: To change driver access group, reload the driver using -g <desired_group> option.
systemctl status sep5.service
● sep5.service - systemd script to load sep5 driver at boot time
     Loaded: loaded (/usr/lib/systemd/system/sep5.service; enabled; preset: enabled)
     Active: active (exited) since Mon 2024-05-20 15:06:16 EEST; 2min 27s ago
    Process: 810 ExecStart=/usr/local/sbin/sep5-load.sh start (code=exited, status=0/SUCCESS)
   Main PID: 810 (code=exited, status=0/SUCCESS)
        CPU: 660ms
May 20 15:06:16 my-machine systemd[1]: Finished sep5.service - systemd script to load sep5 driver at boot time.
My OS: Ubuntu 22.04 LTS with 6.9.0-lowlatency1.
Now my system is good for VTune.
Thank you @Cathy .
A good day.
CFR
New Contributor II
Was having the same issue for RedHat 9 and this seems to have solved it as well.
