Analyzers
5284 Discussions
Mismatch GCC version in Ubuntu 22.04 cause failing installation for Intel VTune
IonutNechita
Default GCC in Ubuntu 22.04 LTS is GCC-11.
But Kernel HWE in Ubuntu 22.04 is 6.5 now, and this is compiled with GCC-12.
I notice one behaviour with GCC mismatch. VTune report failing installation.
 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/561 MB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 241335 files and directories currently installed.)
Preparing to unpack .../intel-oneapi-vtune_2024.1.0-515_amd64.deb ...
Warning:  no socwatch driver was found loaded in the kernel.
Using C compiler = gcc
Using kernel build dir = /lib/modules/6.5.0-35-generic/build
No module symvers file found
Using common inc dir = /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/../common/include
"/lib/modules/6.5.0-35-generic/build/include/linux/cpufreq.h" exists!
Using file name sw_driver
Make args = KERNEL_SRC_DIR=/lib/modules/6.5.0-35-generic/build CPUFREQ_FIX_BACKPORTED=1 DO_DEBUG_BUILD=0 DO_PROFILING=0 COMMON_INC_DIR=/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/../common/include MODULE_SYMVERS_FILE= FILE_NAME=sw_driver
make -C /lib/modules/6.5.0-35-generic/build M=/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver clean
make[1]: Entering directory '/usr/src/linux-headers-6.5.0-35-generic'
make[1]: Leaving directory '/usr/src/linux-headers-6.5.0-35-generic'
Warning:  no vtsspp driver was found loaded in the kernel.
  CLEAN   /opt/intel/oneapi/vtune/2024.1/sepdk/src/vtsspp
Warning:  the following driver(s) were not found loaded in the kernel:  sep5.
Warning: skipping SOCWATCH driver unload, not built
Warning:  the following driver(s) were not found loaded in the kernel:  socperf3.
The PAX service is not loaded anymore.
No previously installed pax driver boot script was found.
Stop and disable sep5.service ...
Removed /etc/systemd/system/multi-user.target.wants/sep5.service.
done.
rm -f sep5*.ko
make[1]: Entering directory '/opt/intel/oneapi/vtune/2024.1/sepdk/src/pax'
rm -f *.o .*.o.cmd .*.o.d .*.ko.cmd .*.ko.unsigned.cmd *.gcno .cache.mk *.o.ur-safe .*.o.tmp *.mod .*.mod.cmd
rm -f pax.ko pax.ko.unsigned pax-x32_64-6.5.0-35-genericsmp.ko
rm -f Module.symvers Modules.symvers *.mod.c modules.order Module.markers .modules.order.cmd .Module.symvers.cmd
rm -rf .tmp_versions
rm -f pax*.ko
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2024.1/sepdk/src/pax'
make[1]: Entering directory '/opt/intel/oneapi/vtune/2024.1/sepdk/src/socperf/src'
rm -f socperf3.ko socperf3.ko.unsigned
rm -f socperf3*x32_64-6.5.0-35-genericsmp.ko
rm -f socperf3*.ko
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2024.1/sepdk/src/socperf/src'
Unpacking intel-oneapi-vtune (2024.1.0-515) over (2024.1.0-515) ...
Setting up intel-oneapi-vtune (2024.1.0-515) ...
C compiler version: 11.4.0
Make version: 4.3
Kernel version: 6.5.0-35-generic
Cleaning workspaces ...
Done
Building socperf driver ...
warning: the compiler differs from the one used to build the kernel
  The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
  You are using:           gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
gcc: error: unrecognized command-line option ‘-ftrivial-auto-var-init=zero’
make[3]: *** [scripts/Makefile.build:251: /opt/intel/oneapi/vtune/2024.1/sepdk/src/socperf/src/socperfdrv.o] Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: *** [scripts/Makefile.build:251: /opt/intel/oneapi/vtune/2024.1/sepdk/src/socperf/src/control.o] Error 1
make[3]: *** [scripts/Makefile.build:251: /opt/intel/oneapi/vtune/2024.1/sepdk/src/socperf/src/utility.o] Error 1
make[3]: *** [scripts/Makefile.build:251: /opt/intel/oneapi/vtune/2024.1/sepdk/src/socperf/src/pmu_list.o] Error 1
make[2]: *** [Makefile:2039: /opt/intel/oneapi/vtune/2024.1/sepdk/src/socperf/src] Error 2
make[1]: *** [Makefile:145: default] Error 2
make: *** [Makefile:219: default] Error 2
Failed to build the drivers
PYTHON is set to python3
ERROR: sep5 driver "sep5-x32_64-6.5.0-35-genericsmp.ko"
was not found in directory "." !
This means you may need to build sep5 driver from the provided
driver sources. Please see the driver README for instructions.
Note: Ensure that the driver is built for kernel version 6.5.0-35-generic
Configuring sep5 boot script with the following options:
    driver files = /opt/intel/oneapi/vtune/2024.1/sepdk/src/.
Creating systemd load script /usr/local/sbin/sep5-load.sh ...
done.
Creating systemd boot config file /lib/systemd/system/sep5.service ...
done.
Configuring autoload of sep5.service service ...
Created symlink /etc/systemd/system/multi-user.target.wants/sep5.service → /lib/systemd/system/sep5.service.
Job for sep5.service failed because the control process exited with error code.
See "systemctl status sep5.service" and "journalctl -xeu sep5.service" for details.
WARNING: systemctl start returned error 1 ...
done.
How is possible to install correctly VTune with GCC-12 as default version in Ubuntu?
yuzhang3_intel
Specify the gcc12 to build the sepdk driver again.
yuzhang3@yuzhang3-10710:~/Downloads/sep/sepdk_2024.1/src$ ./build-driver
C compiler to use: [ /bin/gcc ]       /bin/gcc-12
yuzhang3_intel
Could you try with gcc 12.x to build the driver?
warning: the compiler differs from the one used to build the kernel The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0 You are using: gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0 gcc: error: unrecognized command-line option ‘-ftrivial-auto-var-init=zero’
IonutNechita
yuzhang3_intel
IonutNechita
IonutNechita
This is working correctly.
Thank you.
# :/opt/intel/oneapi/vtune/2024.1/sepdk/src# ./build-driver
C compiler to use: [ /bin/gcc ] /usr/bin/gcc-12
C compiler version: 12.3.0
Make command to use: [ /bin/make ] /usr/bin/make
Make version: 4.3
Kernel source directory: [ /lib/modules/6.5.0-35-generic/build ]
Done
  You are using:           gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
Skipping BTF generation for /opt/intel/oneapi/vtune/2024.1/sepdk/src/socperf/src/socperf3.ko due to unavailability of vmlinux
Done
Building sep driver ...
/opt/intel/oneapi/vtune/2024.1/sepdk/src/sys64.o: warning: objtool: SYS_Get_GDT_Base+0x3: 'naked' return found in RETHUNK build
/opt/intel/oneapi/vtune/2024.1/sepdk/src/sys64.o: warning: objtool: SYS_IO_Delay+0x0: 'naked' return found in RETHUNK build
Skipping BTF generation for /opt/intel/oneapi/vtune/2024.1/sepdk/src/sep5.ko due to unavailability of vmlinux
Done
Building pax driver ...
Skipping BTF generation for /opt/intel/oneapi/vtune/2024.1/sepdk/src/pax/pax.ko due to unavailability of vmlinux
Done
Building vtsspp driver ...
make[1]: Entering directory '/opt/intel/oneapi/vtune/2024.1/sepdk/src/vtsspp'
Skipping BTF generation for /opt/intel/oneapi/vtune/2024.1/sepdk/src/vtsspp/vtsspp.ko due to unavailability of vmlinux
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2024.1/sepdk/src/vtsspp'
Done
Building socwatch driver ...
Building drivers for Linux target
-n switch is deprecated. Now it does not have any effect.
/lib/modules/6.5.0-35-generic/build will be used as the kernel build directory
Removing previously built driver and scripts from /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/drivers
-c /usr/bin/gcc-12 -l -k /lib/modules/6.5.0-35-generic/build will be used to build the SoCWatch driver
************ Building socwatch2_15-x32_64-6.5.0-35-genericsmp.ko driver ************
Using C compiler = /usr/bin/gcc-12
make[1]: Entering directory '/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver'
make[2]: Entering directory '/usr/src/linux-headers-6.5.0-35-generic'
make[2]: Leaving directory '/usr/src/linux-headers-6.5.0-35-generic'
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver'
DO_DRIVER_PROFILING=0
INCDIR_1=/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/../common/include
make -C /lib/modules/6.5.0-35-generic/build M=/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver modules PWD=/opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_driver.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_hardware_io.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_output_buffer.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_tracepoint_handlers.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_collector.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_mem.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_internal.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_file_ops.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_ops_provider.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_trace_notifier_provider.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_reader.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_telem.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_pmt.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_counter_list.o
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/./src/sw_pci.o
  LD [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/socwatch2_15.o
  MODPOST /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/Module.symvers
  CC [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/socwatch2_15.mod.o
  LD [M]  /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko
  BTF [M] /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko
Skipping BTF generation for /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko due to unavailability of vmlinux
************ Built drivers are copied to /opt/intel/oneapi/vtune/2024.1/sepdk/src/socwatch/drivers directory ************
Done
Done building the drivers
