Analyzers
strange cpu usage
softarts
a sniffer program, usually 'top' shows cpu usage is about 6%
when I add the below trivial code, cpu usage jump to 86%!
vtune analysis result:(lightweight hotspot)
void dummyprocessPacket(char *packeT0
int i;
for (i=0;i<800;i++) cpu time:66.878s
int s = 86400+i; 38.765s
int j=s+2345; 122.333s
//other normal processing
the call stack is:
void packet_capture()
while (1)
if (packet_recv(fd)>0) //received
dummyprocesspacket();
bottom-up:
packet_capture ----0.389s
dummyProcessPacket----229.577s
memcpy ....0.141s
any idea to solve this problem,will the 'top'be not accurate?
Peter_W_Intel
What I can suggest is to do dummyProcessPacket() in other thread(s).
Are you working on multi-core system?
Regards, Peter
