Analyzers
5255 Discussions
system wide or per process statistics
stardust496
Greetings,
I have a simple question - I have a program on linux . This program will first pin itself to a particular core and then fork and the forked child will pin itself to a core on a different physical socket
Now, I launch this program from vtune's CLI amplxe-cli -collect nehalem_memory-access collector
Now, the stats that are gathered - are these per physical socket or systemwide for all physical sockets?
Is there a way to see the stats for only one physical socket (since I do not care about what the forked child on a different socket is doing)
Thank you very much!
TimP
There are system-wide statistics and per-thread statistics. According to what you said, you should be able to identify the thread you are interested in.
Peter_W_Intel
If the user run the program which forks child, whatever it works on same core or on a different core -the user should use system wide data collection. Allperformance data are for all physical (and logical) cores, collecting data for special core(s)is not allowed.
For example, use - "amplxe-cl collectnehalem_memory-access -follow-child -analyze-system -- appname"
Sometime, if your mainprocess ran shortly - data collection will stop evenfolked progress still ran. It's better use this example, "amplxe-cl collectnehalem_memory-access -analyze-system -duration 360" (you have to launch your application manually). You may stop data collection before duration timeis out.
Regards, Peter
