Analyzers
5253 Discussions
top down tree shows memory address instead of source code
Rebecca_J_
I run my program and collect hotspots.
When I open the vtune gui and click on the top-down tree toggle and click to see the a file I can only see the assembly language and not my Fortran source code.
Does anyone have any idea why this happens?
TimP
Which possibilities have you eliminated?
e.g.
compilation or link without debug symbols
.pdb or source code not on VTune search path
Hagen_G_
I just had a similar problem, too. In my case the reason was that .exe and .pdb were not matching. (I had updated my local binaries from our server while a compilation ran on the server and thus I got mixed-up files.) Analysing the problem was possible by attaching to my process with wd_express (the visual studio debugger) and seeing that the .pdb file was not loaded although all paths were set correctly.
Perhaps VTune could give the user hints about not-matching binary and pdb files, so we are able to detect such problems on the user-side faster (or "more adequate")? (The current behaviour seems really to be that simply the assemby is shown rather than the source code.)
@Tim: I think that a missing source directory cannot be the problem here - as far as I know, VTune opens up a dialog to choose the source code folder in the case that it doesn't find it automatically.
Hagen
Peter_W_Intel
@Hagen
You can modify VTune(TM) Amplifier's Project Properties to set search Dirs for source/binray/symbol. If you already collected data, you can re-resolve the result again. In command line, you can do "amplxe-cl -finalize -search-dir sym:rp=dir1 -r result-dir"
On GUI, usually VTune will not ask you again if you failed to specify symbol directory first time, just use "re-resolve".
