Analyzers
5250 토론
unable to build sep driver for vtune 2024.2 on ubuntu 24.04
JiyuanZhang
초급자
2,411 조회수
Hello! I'm new to vtune and I just want to install the vtune 2024.2 into ubuntu 24.04. I downloaded the whole intel oneapi base-toolkit and run sudo ./build-driver. The socperf driver is built successfully but the sep driver fails. The details are as follows. I will really appreciate it if you are willing to help!
jiyuanzhang@jiyuanzhang-VMware-Virtual-Platform:/opt/intel/oneapi/vtune/latest/sepdk/src$ sudo ./build-driver
C compiler to use: [ /bin/gcc ]
C compiler version: 13.2.0
Make command to use: [ /bin/make ]
Make version: 4.3
Kernel source directory: [ /lib/modules/6.8.0-35-generic/build ]
Kernel version: 6.8.0-35-generic
Cleaning workspaces ...
Done
Building socperf driver ...
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-13 (Ubuntu 13.2.0-23ubuntu4) 13.2.0
You are using: gcc (Ubuntu 13.2.0-23ubuntu4) 13.2.0
Skipping BTF generation for /opt/intel/oneapi/vtune/2024.2/sepdk/src/socperf/src/socperf3.ko due to unavailability of vmlinux
Done
Building sep driver ...
/opt/intel/oneapi/vtune/2024.2/sepdk/src/sys64.o: warning: objtool: SYS_Get_GDT_Base+0x3: 'naked' return found in RETHUNK build
/opt/intel/oneapi/vtune/2024.2/sepdk/src/sys64.o: warning: objtool: SYS_IO_Delay+0x0: 'naked' return found in RETHUNK build
make[3]: *** [scripts/Makefile.build:361: /opt/intel/oneapi/vtune/2024.2/sepdk/src/sys64.o] Error 254
make[3]: *** Deleting file '/opt/intel/oneapi/vtune/2024.2/sepdk/src/sys64.o'
make[3]: *** Waiting for unfinished jobs....
make[2]: *** [/usr/src/linux-headers-6.8.0-35-generic/Makefile:1926: /opt/intel/oneapi/vtune/2024.2/sepdk/src] Error 2
make[1]: *** [Makefile:240: __sub-make] Error 2
make: *** [Makefile:224: default] Error 2
Failed to build the drivers
0 포인트
4 응답
yuzhang3_intel
중재자
2,333 조회수
This is fixed in the coming 2024.2.1 release.
0 포인트
jicheng
초급자
2,049 조회수
Hello, where can I get a previously working version? Thanks.
0 포인트
yuzhang3_intel
중재자
1,948 조회수
0 포인트
jicheng
초급자
1,891 조회수
That's unfortunate. Looking forward to your new version.
0 포인트
응답
