Analyzers
5271 Discussions
unable to stop driver (error=89)
fauzia
I am trying to get some samples ..actually a lot of data. After 3 hours, the program finishes and I get the following error
[ERROR] Attempt to perform sampling failed.
[ERROR] unable to stop driver (error=89): sample file creation failed
I checked the time duration I have used (using -d option). It should be ok if there is no time limit. Is there any time limit?
Kevin_Magee__Intel_
The same error message is discussed in this thread. It looks like there are some good suggestions there.
Best,
-Kevin
