Analyzers
5307 Discussions
unsolved memeory error of build-in qt application
yani_d_
I am running intel inspector XE 2013 for a demo of QT application. it turns out lots of lots of errors such as Kernel resource leak, Memory leak, Uninitialized memory access...error
I go to call stacks for one of the memory leak, but all of them point the QT model , function and filename.call stack
How should I solve this problems?  or they are ignorable? any help will be appreciated.
yani_d_
I attach the screenshot of my previous post
Peter_W_Intel
In general speaking, you have no way to change code in QT library for kernel resource issue, so you may use option "-knob detect-resource-leaks=false" to filter these data.
You also might filter some errors located at some system dlls, i.e. ole32.dll - for example, use below option:
"-module-filter-mode=exclude -module-filter=ole32.dll" or "-module-filter-mode=include -module-filter=interview.exe"
You may focus the errors which can locate at your demo source.
