Analyzers
vtl command not found
david_z_
I've installed an evaluation version of vtune_amplifier_xe_2013_update17 on my SLES 11.2. I'm trying to collect data from command line and export t a .csv file. However, I failed when I use vtl with this error:
bash: vtl: command not found
Anyone could please help on this? Thank you:)
Dmitry_P_Intel1
As I remember vtl was a command line utility in old product VTune Performance Analyzer.
In VTune Amplifier XE the command line utility is named amplxe-cl  and resides in <VTune_install_dir>/bin64 or <VTune_install_dir>/bin32.
BTW - they are not comatible by CL options so you might need to tweak your scripts if any according to the new CL: https://software.intel.com/en-us/node/529435
Thanks & Regards, Dmitry
Dmitry_P_Intel1
david_z_
I didn't see that:( Thank you @dmitry-prohorov (Intel).
