Analyzers
5206 Discussions
vtune CLI report: how to get "Average Latency (cycles)" metric for memory analysis?
Pramod_K_
Dear All,
I have generated a Vtune profile using the command:
vtune -collect memory-access -result-dir=linreg_meman -knob analyze-mem-objects=true -knob mem-object-size-min-thres=1 -knob dram-bandwidth-limits=true ./lreg-pthread key_file.txt
And in the UI I see the "Average Latency" as below:
I tried
vtune -report top-down -r linreg_meman  -column="Average Latency"
But I don't get the same results:
Any suggestions?
(I see that in UI we have `Bottom-up` whereas CLI `top-down`. That's because there is no `Bottom-up` report type in report CLI,)
yuzhang3_intel
VTune report supports 'hotspots' to correspond to GUI page 'Bottom-up', like below:
$ vtune -report hotspots -r ../linreg_meman -colum='Average Latency (cycles):Self' -S='Average Latency (cycles):Self'
You can also use the '-s' or '-S' option to sort the results you are interested in as above.
In addition, you can get support from $vtune -help for details.
$ vtune -help report
