Analyzers
5342 Discussions
vtune and optimization flag problem
amk21
I found out that when compileing with -O flag it's does not meter what optimize flag i'm using once -O is specify vtune stop collecting data.
i installed a clean Ubuntu 11.1
amir@ubuntu:~/vtune_intel_test$ uname -a
Linu
x ubuntu 3.0.0-12-server #20-Ubuntu SMP Fri Oct 7 16:36:30 UTC 2011 x86_64 x86_64 x86_64 GNU/Linux
compile with -O
g++ test.cpp -g -I/opt/intel/vtune_amplifier_xe_2011/include /opt/intel/vtune_amplifier_xe_2011/lib64/libittnotify.a -lpthread -ldl -O -o test
amir@ubuntu:~/vtune_intel_test$ rm -Rf r00*; amplxe-cl -collect hotspots -start-paused -- ./test; amplxe-cl -report hotspots r000hs/
Error: Cannot change state
Using result path `/home/amir/vtune_intel_test/r000hs'
Executing actions 16 % Loading data files
Warning: Cannot load data file `/home/amir/vtune_intel_test/r000hs/data.0/11058-11066.0.log' ().
Executing actions 75 % Generating a report
Summary
Elapsed Time: 0.021
CPU Time: 0
Executing actions 100 % done
Function Module CPU Time
compile without
amir@ubuntu:~/vtune_intel_test$ g++ test.cpp -g -I/opt/intel/vtune_amplifier_xe_2011/include /opt/intel/vtune_amplifier_xe_2011/lib64/libittnotify.a -lpthread -ldl -o test
Warning: Cannot load data file `/home/amir/vtune_intel_test/r000hs/data.0/11128-11136.0.log' ().
Summary
Elapsed Time: 0.102
CPU Time: 0.027
foo_data_collected test 0.027
this is the test.cpp code
//test.cpp : Defines the entry point for the console application.
#include "ittnotify.h"
void foo_data_collected()
for (int i=0; i<10000000L; i++);
void foo_data_not_collected()
int main(int argc, char* argv[])
// Assume that data collector was paused in user interface
foo_data_not_collected();
// Now resume data collecting
__itt_resume();
foo_data_collected();
// Pasue data collecting again
__itt_pause();
// Resume data collecting again
__itt_resume();
// The user shouldn't see data collecting in foo_data_not_collected() in result
return 0;
how can i use vtune whith -O2 or -O3 ?
Amir
Rob5
New Contributor II
Amk21,
This new forum post appears to be a duplicate of forum thread hereyou posted which is in process. Let us know if this is not the case.
- Rob
amk21
this is more direct question way gcc optimization flag cause vtune to stop collecting in the previous post there where several issues
Peter_W_Intel
I never use option "-Ox" when I tried Resume/Pause API. But I think this should be a probelm.
I have reported this problem to engineering team, and willupdate on this thread if any progress.
Currently, workaround is not to use "-Ox" when using Resume/Pause API.
Regards, Peter
amk21
i think i figure the problem the functions are inline when using -Ox flag
TimP
Inlined functions will cause the associated data to be associated with a calling function. So it's often useful to disable in-lining for profiling.
