Analyzers
vtune mpi
侯玉山
hi, I use the VTune command line to analyze the MPI program,But I had some problems.
1)Unable to analyze
command
vtune -collect hpc-performance -k collect-affinity=true -trace-mpi -result-dir /home/hpcadmin/hys/hys_vtune/vtune_projects_dir/test_mpi_dir/mpi_heartdemo_hpc-performance_ppn8_omp3_1node_170 -- mpiexec -genv I_MPI_DEBUG=4 -n 16 -ppn 8 -hosts c1 /home/hpcadmin/hys/hys_vtune/vtune_test_code/Cardiac_demo/build/heart_demo -m /home/hpcadmin/hys/hys_vtune/vtune_test_code/Cardiac_demo/mesh_mid -s /home/hpcadmin/hys/hys_vtune/vtune_test_code/Cardiac_demo/setup_mid.txt -t 100
problems:
but it stops here (as shown in the red box). You need to press Ctrl + C to continue collecting,Can you let VTune start analyzing automatically.
2)VTune analyzes MPI multi nodes, one of which is killed
command:
vtune -collect hpc-performance -k collect-affinity=true -trace-mpi -result-dir /home/hpcadmin/hys/hys_vtune/vtune_projects_dir/test_mpi_dir/mpi_heartdemo_hpc-performance_ppn8_omp3_2node_172 -- mpiexec -genv I_MPI_DEBUG=4 -n 16 -ppn 8 -hosts c1,c2 /home/hpcadmin/hys/hys_vtune/vtune_test_code/Cardiac_demo/build/heart_demo -m /home/hpcadmin/hys/hys_vtune/vtune_test_code/Cardiac_demo/mesh_mid -s /home/hpcadmin/hys/hys_vtune/vtune_test_code/Cardiac_demo/setup_mid.txt -t 100
output:
vtune: Analyzing data in the node-wide mode. The hostname (c2) will be added to the result path/name.
vtune: Peak bandwidth measurement started.
vtune: Peak bandwidth measurement finished.
vtune: Warning: To enable hardware event-based sampling, VTune Profiler has disabled the NMI watchdog timer. The watchdog timer will be re-enabled after collection completes.
vtune: Collection started. To stop the collection, either press CTRL-C or enter from another console window: vtune -r /home/hpcadmin/hys/hys_vtune/vtune_projects_dir/test_mpi_dir/mpi_heartdemo_hpc-performance_ppn8_omp3_2node_172.c2 -command stop.
[0] MPI startup(): Intel(R) MPI Library, Version 2021.2 Build 20210302 (id: f4f7c92cd)
[0] MPI startup(): Copyright (C) 2003-2021 Intel Corporation. All rights reserved.
[0] MPI startup(): library kind: release
[0] MPI startup(): libfabric version: 1.11.0-impi
[0] MPI startup(): libfabric provider: verbs;ofi_rxm
[0] MPI startup(): File "/opt/intel/oneapi/mpi/2021.2.0/etc/tuning_icx_shm-ofi_verbs-ofi-rxm.dat" not found
[0] MPI startup(): Load tuning file: "/opt/intel/oneapi/mpi/2021.2.0/etc/tuning_icx_shm-ofi.dat"
[0] MPI startup(): File "/opt/intel/oneapi/mpi/2021.2.0/etc/tuning_icx_shm-ofi.dat" not found
[0] MPI startup(): Load tuning file: "/opt/intel/oneapi/mpi/2021.2.0/etc/tuning_clx-ap_shm-ofi.dat"
MPI rank 1 has started on c1
MPI rank 3 has started on c1
MPI rank 7 has started on c1
MPI rank 5 has started on c1
MPI rank 6 has started on c1
MPI rank 4 has started on c1
MPI rank 2 has started on c1
MPI rank 9 has started on c2
MPI rank 13 has started on c2
MPI rank 14 has started on c2
MPI rank 15 has started on c2
MPI rank 11 has started on c2
MPI rank 12 has started on c2
MPI rank 10 has started on c2
MPI rank 8 has started on c2
[0] MPI startup(): Rank Pid Node name Pin cpu
[0] MPI startup(): 0 1202863 c1 {0,1,2,3,4,5,6,56,57,58,59,60,61,62}
[0] MPI startup(): 1 1202864 c1 {7,8,9,10,11,12,13,63,64,65,66,67,68,69}
[0] MPI startup(): 2 1202865 c1 {14,15,16,17,18,19,20,70,71,72,73,74,75,76}
[0] MPI startup(): 3 1202866 c1 {21,22,23,24,25,26,27,77,78,79,80,81,82,83}
[0] MPI startup(): 4 1202867 c1 {28,29,30,31,32,33,34,84,85,86,87,88,89,90}
[0] MPI startup(): 5 1202868 c1 {35,36,37,38,39,40,41,91,92,93,94,95,96,97}
[0] MPI startup(): 6 1202869 c1 {42,43,44,45,46,47,48,98,99,100,101,102,103,104}
[0] MPI startup(): 7 1202870 c1 {49,50,51,52,53,54,55,105,106,107,108,109,110,111}
[0] MPI startup(): 8 2475730 c2 {0,1,2,3,4,5,6,56,57,58,59,60,61,62}
[0] MPI startup(): 9 2475732 c2 {7,8,9,10,11,12,13,63,64,65,66,67,68,69}
[0] MPI startup(): 10 2475734 c2 {14,15,16,17,18,19,20,70,71,72,73,74,75,76}
[0] MPI startup(): 11 2475737 c2 {21,22,23,24,25,26,27,77,78,79,80,81,82,83}
[0] MPI startup(): 12 2475740 c2 {28,29,30,31,32,33,34,84,85,86,87,88,89,90}
[0] MPI startup(): 13 2475743 c2 {35,36,37,38,39,40,41,91,92,93,94,95,96,97}
[0] MPI startup(): 14 2475746 c2 {42,43,44,45,46,47,48,98,99,100,101,102,103,104}
[0] MPI startup(): 15 2475749 c2 {49,50,51,52,53,54,55,105,106,107,108,109,110,111}
MPI rank 0 has started on c1
Number of Nodes: 28187
Number of Cells: 112790
Root init took 0.180209 secs
rank 0: r_start=0 r_end=1761 r_len=1762
rank 1: r_start=1762 r_end=3523 r_len=1762
rank 2: r_start=3524 r_end=5285 r_len=1762
rank 3: r_start=5286 r_end=7047 r_len=1762
rank 4: r_start=7048 r_end=8809 r_len=1762
rank 5: r_start=8810 r_end=10571 r_len=1762
rank 6: r_start=10572 r_end=12333 r_len=1762
rank 7: r_start=12334 r_end=14095 r_len=1762
rank 8: r_start=14096 r_end=15857 r_len=1762
rank 9: r_start=15858 r_end=17619 r_len=1762
rank 10: r_start=17620 r_end=19381 r_len=1762
rank 11: r_start=19382 r_end=21142 r_len=1761
rank 12: r_start=21143 r_end=22903 r_len=1761
rank 13: r_start=22904 r_end=24664 r_len=1761
rank 14: r_start=24665 r_end=26425 r_len=1761
rank 15: r_start=26426 r_end=28186 r_len=1761
rank 0: non_local_ids.size(): 14787
rank 1: non_local_ids.size(): 13859
rank 2: non_local_ids.size(): 13381
rank 3: non_local_ids.size(): 13508
rank 4: non_local_ids.size(): 13314
rank 5: non_local_ids.size(): 12779
rank 6: non_local_ids.size(): 12766
rank 7: non_local_ids.size(): 12449
rank 8: non_local_ids.size(): 12310
rank 9: non_local_ids.size(): 11962
rank 10: non_local_ids.size(): 12027
rank 11: non_local_ids.size(): 12098
rank 12: non_local_ids.size(): 13454
rank 13: non_local_ids.size(): 13766
rank 14: non_local_ids.size(): 13952
rank 15: non_local_ids.size(): 13578
rank 0: non_loc_dependecies: (1:337) (2:565) (3:1171) (4:1276) (5:1290) (6:1226) (7:1226) (8:1153) (9:1137) (10:1055) (11:740) (12:911) (13:912) (14:944) (15:844)
rank 1: non_loc_dependecies: (0:324) (2:519) (3:1113) (4:1294) (5:1273) (6:1205) (7:1097) (8:1002) (9:886) (10:918) (11:707) (12:882) (13:903) (14:882) (15:854)
rank 2: non_loc_dependecies: (0:538) (1:537) (3:692) (4:933) (5:1034) (6:1099) (7:1118) (8:1128) (9:1119) (10:1048) (11:737) (12:850) (13:845) (14:870) (15:833)
rank 3: non_loc_dependecies: (0:1045) (1:1051) (2:675) (4:762) (5:892) (6:936) (7:974) (8:1021) (9:1003) (10:1016) (11:770) (12:859) (13:853) (14:854) (15:797)
rank 4: non_loc_dependecies: (0:1047) (1:1209) (2:925) (3:781) (5:781) (6:841) (7:890) (8:939) (9:943) (10:889) (11:722) (12:841) (13:844) (14:824) (15:838)
rank 5: non_loc_dependecies: (0:1023) (1:1157) (2:998) (3:870) (4:786) (6:730) (7:827) (8:869) (9:836) (10:875) (11:645) (12:804) (13:794) (14:789) (15:776)
rank 6: non_loc_dependecies: (0:1003) (1:1048) (2:1024) (3:928) (4:859) (5:747) (7:744) (8:779) (9:767) (10:854) (11:695) (12:870) (13:830) (14:828) (15:790)
rank 7: non_loc_dependecies: (0:1009) (1:980) (2:1052) (3:946) (4:863) (5:833) (6:752) (8:722) (9:721) (10:756) (11:667) (12:746) (13:843) (14:828) (15:731)
rank 8: non_loc_dependecies: (0:930) (1:930) (2:1046) (3:935) (4:902) (5:880) (6:780) (7:755) (9:668) (10:705) (11:634) (12:789) (13:776) (14:798) (15:782)
rank 9: non_loc_dependecies: (0:918) (1:844) (2:1019) (3:975) (4:929) (5:834) (6:772) (7:747) (8:681) (10:675) (11:597) (12:748) (13:767) (14:716) (15:740)
rank 10: non_loc_dependecies: (0:891) (1:857) (2:938) (3:1001) (4:875) (5:875) (6:841) (7:767) (8:699) (9:682) (11:620) (12:767) (13:730) (14:750) (15:734)
rank 11: non_loc_dependecies: (0:637) (1:611) (2:654) (3:667) (4:653) (5:611) (6:642) (7:601) (8:581) (9:558) (10:553) (12:1394) (13:1340) (14:1335) (15:1261)
rank 12: non_loc_dependecies: (0:789) (1:773) (2:729) (3:772) (4:743) (5:731) (6:746) (7:648) (8:710) (9:697) (10:692) (11:1348) (13:1386) (14:1350) (15:1340)
rank 13: non_loc_dependecies: (0:795) (1:808) (2:753) (3:800) (4:779) (5:770) (6:774) (7:747) (8:720) (9:757) (10:703) (11:1353) (12:1413) (14:1305) (15:1289)
rank 14: non_loc_dependecies: (0:848) (1:818) (2:800) (3:810) (4:827) (5:757) (6:789) (7:802) (8:781) (9:732) (10:713) (11:1343) (12:1379) (13:1333) (15:1220)
rank 15: non_loc_dependecies: (0:785) (1:805) (2:806) (3:794) (4:771) (5:762) (6:767) (7:733) (8:769) (9:731) (10:699) (11:1257) (12:1372) (13:1302) (14:1225)
rank 0: num_remote_dependees: [0:0] [1:324] [2:538] [3:1045] [4:1047] [5:1023] [6:1003] [7:1009] [8:930] [9:918] [10:891] [11:637] [12:789] [13:795] [14:848] [15:785]
rank 1: num_remote_dependees: [0:337] [1:0] [2:537] [3:1051] [4:1209] [5:1157] [6:1048] [7:980] [8:930] [9:844] [10:857] [11:611] [12:773] [13:808] [14:818] [15:805]
rank 2: num_remote_dependees: [0:565] [1:519] [2:0] [3:675] [4:925] [5:998] [6:1024] [7:1052] [8:1046] [9:1019] [10:938] [11:654] [12:729] [13:753] [14:800] [15:806]
rank 3: num_remote_dependees: [0:1171] [1:1113] [2:692] [3:0] [4:781] [5:870] [6:928] [7:946] [8:935] [9:975] [10:1001] [11:667] [12:772] [13:800] [14:810] [15:794]
rank 4: num_remote_dependees: [0:1276] [1:1294] [2:933] [3:762] [4:0] [5:786] [6:859] [7:863] [8:902] [9:929] [10:875] [11:653] [12:743] [13:779] [14:827] [15:771]
rank 5: num_remote_dependees: [0:1290] [1:1273] [2:1034] [3:892] [4:781] [5:0] [6:747] [7:833] [8:880] [9:834] [10:875] [11:611] [12:731] [13:770] [14:757] [15:762]
rank 6: num_remote_dependees: [0:1226] [1:1205] [2:1099] [3:936] [4:841] [5:730] [6:0] [7:752] [8:780] [9:772] [10:841] [11:642] [12:746] [13:774] [14:789] [15:767]
rank 7: num_remote_dependees: [0:1226] [1:1097] [2:1118] [3:974] [4:890] [5:827] [6:744] [7:0] [8:755] [9:747] [10:767] [11:601] [12:648] [13:747] [14:802] [15:733]
rank 8: num_remote_dependees: [0:1153] [1:1002] [2:1128] [3:1021] [4:939] [5:869] [6:779] [7:722] [8:0] [9:681] [10:699] [11:581] [12:710] [13:720] [14:781] [15:769]
rank 9: num_remote_dependees: [0:1137] [1:886] [2:1119] [3:1003] [4:943] [5:836] [6:767] [7:721] [8:668] [9:0] [10:682] [11:558] [12:697] [13:757] [14:732] [15:731]
rank 10: num_remote_dependees: [0:1055] [1:918] [2:1048] [3:1016] [4:889] [5:875] [6:854] [7:756] [8:705] [9:675] [10:0] [11:553] [12:692] [13:703] [14:713] [15:699]
rank 11: num_remote_dependees: [0:740] [1:707] [2:737] [3:770] [4:722] [5:645] [6:695] [7:667] [8:634] [9:597] [10:620] [11:0] [12:1348] [13:1353] [14:1343] [15:1257]
rank 12: num_remote_dependees: [0:911] [1:882] [2:850] [3:859] [4:841] [5:804] [6:870] [7:746] [8:789] [9:748] [10:767] [11:1394] [12:0] [13:1413] [14:1379] [15:1372]
rank 13: num_remote_dependees: [0:912] [1:903] [2:845] [3:853] [4:844] [5:794] [6:830] [7:843] [8:776] [9:767] [10:730] [11:1340] [12:1386] [13:0] [14:1333] [15:1302]
rank 14: num_remote_dependees: [0:944] [1:882] [2:870] [3:854] [4:824] [5:789] [6:828] [7:828] [8:798] [9:716] [10:750] [11:1335] [12:1350] [13:1305] [14:0] [15:1225]
rank 15: num_remote_dependees: [0:844] [1:854] [2:833] [3:797] [4:838] [5:776] [6:790] [7:731] [8:782] [9:740] [10:734] [11:1261] [12:1340] [13:1289] [14:1220] [15:0]
Task initialized & distributed
Solve time: 100 ms with solve step 0.003
starting solution...
RANK 1 is using 3 OMP threads
RANK 0 is using 3 OMP threads
RANK 2 is using 3 OMP threads
RANK 3 is using 3 OMP threads
RANK 4 is using 3 OMP threads
RANK 5 is using 3 OMP threads
RANK 6 is using 3 OMP threads
RANK 7 is using 3 OMP threads
RANK 12 is using 3 OMP threads
RANK 11 is using 3 OMP threads
RANK 10 is using 3 OMP threads
RANK 14 is using 3 OMP threads
RANK 15 is using 3 OMP threads
RANK 8 is using 3 OMP threads
RANK 13 is using 3 OMP threads
RANK 9 is using 3 OMP threads
vcs/collectunits1/tmu/src/tmu.c:939 alloc_record: Assertion '(next)->head <= (next)->write_ptr && (next)->write_ptr <= ((next)->head + (next)->size)' failed.
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 1202863 RUNNING AT c1
= KILLED BY SIGNAL: 6 (Aborted)
= RANK 1 PID 1202864 RUNNING AT c1
= KILLED BY SIGNAL: 9 (Killed)
= RANK 2 PID 1202865 RUNNING AT c1
= RANK 3 PID 1202866 RUNNING AT c1
= RANK 4 PID 1202867 RUNNING AT c1
= RANK 5 PID 1202868 RUNNING AT c1
= RANK 6 PID 1202869 RUNNING AT c1
= RANK 7 PID 1202870 RUNNING AT c1
vtune: Collection stopped.
vtune: Using result path `/home/hpcadmin/hys/hys_vtune/vtune_projects_dir/test_mpi_dir/mpi_heartdemo_hpc-performance_ppn8_omp3_2node_172.c2'
vtune: Executing actions 19 % Resolving information for `libshm-fi.so'
vtune: Warning: Cannot locate debugging information for file `/opt/intel/oneapi/mpi/2021.2.0/libfabric/lib/prov/libshm-fi.so'.
vtune: Warning: Cannot locate debugging information for file `/usr/lib64/ld-2.28.so'.
vtune: Warning: Cannot locate file `ib_core.ko'.
vtune: Executing actions 19 % Resolving information for `ib_core'
vtune: Warning: Cannot locate file `nfs.ko'.
vtune: Executing actions 19 % Resolving information for `nfs'
vtune: Warning: Cannot locate file `xfs.ko'.
vtune: Warning: Cannot locate file `sep5.ko'.
vtune: Executing actions 19 % Resolving information for `sep5'
vtune: Warning: Cannot locate file `mlx5_ib.ko'.
vtune: Executing actions 19 % Resolving information for `mlx5_ib'
vtune: Warning: Cannot locate file `bnxt_en.ko'.
vtune: Executing actions 19 % Resolving information for `bnxt_en'
vtune: Warning: Cannot locate debugging information for file `/opt/intel/oneapi/vtune/2021.5.0/lib64/runtime/libittnotify_collector.so'.
vtune: Executing actions 20 % Resolving information for `libpthread-2.28.so'
vtune: Warning: Cannot locate debugging information for file `/usr/lib64/libpthread-2.28.so'.
vtune: Executing actions 20 % Resolving information for `libmpi.so.12.0.0'
vtune: Warning: Cannot locate debugging information for file `/usr/lib64/libc-2.28.so'.
vtune: Warning: Cannot locate file `rdma_ucm.ko'.
vtune: Executing actions 20 % Resolving information for `librdmacm.so.1.2.29.0'
vtune: Warning: Cannot locate debugging information for file `/usr/lib64/librdmacm.so.1.2.29.0'.
vtune: Executing actions 20 % Resolving information for `ssh'
vtune: Warning: Cannot locate file `mlx5_core.ko'.
vtune: Executing actions 20 % Resolving information for `mlx5_core'
vtune: Warning: Cannot locate debugging information for file `/usr/bin/ssh'.
vtune: Executing actions 20 % Resolving information for `libcrypto.so.1.1.1g'
vtune: Warning: Cannot locate debugging information for file `/opt/intel/oneapi/mpi/2021.2.0/libfabric/lib/prov/librxm-fi.so'.
vtune: Executing actions 20 % Resolving information for `libnl-3.so.200.26.0'
vtune: Warning: Cannot locate debugging information for file `/usr/lib64/libcrypto.so.1.1.1g'.
vtune: Warning: Cannot locate debugging information for file `/usr/lib64/libnl-3.so.200.26.0'.
vtune: Executing actions 21 % Resolving information for `libbnxt_re-rdmav25.so'
vtune: Warning: Cannot locate debugging information for file `/usr/lib64/libibverbs/libbnxt_re-rdmav25.so'.
vtune: Executing actions 21 % Resolving information for `libibverbs.so.1.8.29.0
vtune: Warning: Cannot locate debugging information for file `/usr/lib64/libibverbs.so.1.8.29.0'.
vtune: Executing actions 21 % Resolving information for `libverbs-fi.so'
vtune: Warning: Cannot locate debugging information for file `/opt/intel/oneapi/mpi/2021.2.0/libfabric/lib/prov/libverbs-fi.so'.
vtune: Warning: Cannot locate file `bnxt_re.ko'.
vtune: Executing actions 21 % Resolving information for `libfabric.so.1'
vtune: Warning: Cannot locate debugging information for file `/opt/intel/oneapi/mpi/2021.2.0/libfabric/lib/libfabric.so.1'.
vtune: Executing actions 21 % Resolving information for `libnss_files-2.28.so'
vtune: Warning: Cannot locate debugging information for file `/usr/lib64/libnss_files-2.28.so'.
vtune: Executing actions 21 % Resolving information for `libiomp5.so'
vtune: Warning: Cannot locate debugging information for the Linux kernel. Source-level analysis will not be possible. Function-level analysis will be limited to kernel symbol tables. See the Enabling Linux Kernel Analysis topic in the product online help for instructions.
vtune: Warning: Cannot locate file `ib_uverbs.ko'.
vtune: Executing actions 22 % Resolving information for `libmlx5.so.1.13.29.0'
vtune: Warning: Cannot locate debugging information for file `/usr/lib64/libmlx5.so.1.13.29.0'.
vtune: Executing actions 75 % Generating a report Elapsed Time: 59.306s
SP GFLOPS: 0.000
DP GFLOPS: 0.267
x87 GFLOPS: 0.000
CPI Rate: 1.297
| The CPI may be too high. This could be caused by issues such as memory
| stalls, instruction starvation, branch misprediction or long latency
| instructions. Explore the other hardware-related metrics to identify what
| is causing high CPI.
Average CPU Frequency: 3.261 GHz
Total Thread Count: 37
Effective Physical Core Utilization: 13.1% (7.334 out of 56)
| The metric value is low, which may signal a poor physical CPU cores
| utilization caused by:
| - load imbalance
| - threading runtime overhead
| - contended synchronization
| - thread/process underutilization
| - incorrect affinity that utilizes logical cores instead of physical
| cores
| Explore sub-metrics to estimate the efficiency of MPI and OpenMP parallelism
| or run the Locks and Waits analysis to identify parallel bottlenecks for
| other parallel runtimes.
Effective Logical Core Utilization: 6.6% (7.403 out of 112)
| The metric value is low, which may signal a poor logical CPU cores
| utilization. Consider improving physical core utilization as the first
| step and then look at opportunities to utilize logical cores, which in
| some cases can improve processor throughput and overall performance of
| multi-threaded applications.
Memory Bound: 31.5% of Pipeline Slots
| The metric value is high. This can indicate that the significant fraction of
| execution pipeline slots could be stalled due to demand memory load and
| stores. Use Memory Access analysis to have the metric breakdown by memory
| hierarchy, memory bandwidth information, correlation by memory objects.
Cache Bound: 25.6% of Clockticks
| A significant proportion of cycles are being spent on data fetches from
| caches. Check Memory Access analysis to see if accesses to L2 or L3
| caches are problematic and consider applying the same performance tuning
| as you would for a cache-missing workload. This may include reducing the
| data working set size, improving data access locality, blocking or
| partitioning the working set to fit in the lower cache levels, or
| exploiting hardware prefetchers. Consider using software prefetchers, but
| note that they can interfere with normal loads, increase latency, and
| increase pressure on the memory system. This metric includes coherence
| penalties for shared data. Check Microarchitecture Exploration analysis
| to see if contested accesses or data sharing are indicated as likely
| issues.
DRAM Bound: 8.4% of Clockticks
DRAM Bandwidth Bound: 0.0% of Elapsed Time
NUMA: % of Remote Accesses: 0.0%
Bandwidth Utilization
Bandwidth Domain Platform Maximum Observed Maximum Average % of Elapsed Time with High BW Utilization(%)
DRAM, GB/sec 150 15.600 2.860 0.0%
DRAM Single-Package, GB/sec 75 8.600 1.440 0.0%
Vectorization: 0.0% of Packed FP Operations
Instruction Mix
SP FLOPs: 0.0% of uOps
Packed: 0.0% from SP FP
128-bit: 0.0% from SP FP
256-bit: 0.0% from SP FP
512-bit: 0.0% from SP FP
Scalar: 0.0% from SP FP
DP FLOPs: 0.9% of uOps
Packed: 0.0% from DP FP
128-bit: 0.0% from DP FP
256-bit: 0.0% from DP FP
512-bit: 0.0% from DP FP
Scalar: 100.0% from DP FP
x87 FLOPs: 0.0% of uOps
Non-FP: 99.1% of uOps
FP Arith/Mem Rd Instr. Ratio: 0.034
FP Arith/Mem Wr Instr. Ratio: 0.089
Collection and Platform Info
Application Command Line: mpiexec "-genv" "I_MPI_DEBUG=4" "-n" "16" "-ppn" "8" "-hosts" "c1,c2" "/home/hpcadmin/hys/hys_vtune/vtune_test_code/Cardiac_demo/build/heart_demo" "-m" "/home/hpcadmin/hys/hys_vtune/vtune_test_code/Cardiac_demo/mesh_mid" "-s" "/home/hpcadmin/hys/hys_vtune/vtune_test_code/Cardiac_demo/setup_mid.txt" "-t" "100"
User Name: root
Operating System: 4.18.0-240.el8.x86_64 \S Kernel \r on an \m
Computer Name: c2
Result Size: 421.9 MB
Collection start time: 02:00:53 05/07/2021 UTC
Collection stop time: 02:01:53 05/07/2021 UTC
Collector Type: Event-based sampling driver,User-mode sampling and tracing
CPU
Name: Intel(R) Xeon(R) Processor code named Icelake
Frequency: 2.195 GHz
Logical CPU Count: 112
Max DRAM Single-Package Bandwidth: 75.000 GB/s
If you want to skip descriptions of detected performance issues in the report,
enter: vtune -report summary -report-knob show-issues=false -r <my_result_dir>.
Alternatively, you may view the report in the csv format: vtune -report
<report_name> -format=csv.
vtune: Executing actions 100 % done
I want to know what causes this, what solutions are available to deal with these problems, and whether the multi node MPI program can collect information from multiple nodes. Thanks for your help.
Labels (2)
Dmitry_P_Intel1
Could you please run VTune collection in the following notation:
mpiexec -genv I_MPI_DEBUG=4 -n 16 -ppn 8 -hosts c1,c2 vtune -collect hpc-performance -k collect-affinity=true -trace-mpi -result-dir /home/hpcadmin/hys/hys_vtune/vtune_projects_dir/test_mpi_dir/mpi_heartdemo_hpc-performance_ppn8_omp3_2node_172 -- /home/hpcadmin/hys/hys_vtune/vtune_test_code/Cardiac_demo/build/heart_demo -m /home/hpcadmin/hys/hys_vtune/vtune_test_code/Cardiac_demo/mesh_mid -s /home/hpcadmin/hys/hys_vtune/vtune_test_code/Cardiac_demo/setup_mid.txt -t 100
So you need to run VTune CL under the MPI launcher. You can also switch off data limit to do collection for the whole run adding "-data-limit=0" to the VTune command line.
BTW: it might be worth to read VTune Cookbook on how to use it on MPI apps: https://software.intel.com/content/www/us/en/develop/documentation/vtune-cookbook/top/configuration-recipes/profiling-mpi-applications.html.
Thanks & Regards, Dmitry
RahulU_Intel
Thanks for posting in Intel forums. We are looking into your case. We will get back to you.
Dmitry_P_Intel1
侯玉山
Thank you for your reply, which solved my problem.
I can analyze MPI multiprocessor program with VTune now.
thanks.
RahulU_Intel
Thanks for the confirmation. This thread will no longer be monitored. If you have any other query you can post a new question.
Rahul
