Analyzers
5279 讨论
vtune stalled when finalizing results
maxRoll7
初学者
1,531 次查看
Hi
vtune can't finalizing the memory access result.
It always stalled on 45%.
And I have dump some logs.
Any suggestions would be greatly appreciated.
0 项奖励
1 回复
optimizergal
新分销商 I
1,007 次查看
In your other post, it mentions that it might be slow getting symbols from the server specified in  _NT_SYMBOL_PATH. If the connection to the symbol server is slow, you can try to work around it as described here:
https://www.intel.com/content/www/us/en/docs/vtune-profiler/user-guide/2025-4/problem-gui-hangs-or-crashes.html
Since finalization looks like it's stuck on a driver, that might not be the problem. Does it only hang on the memory analysis?
0 项奖励
回复
