Analyzers
5255 Discussions
vtune with sudo access doesn't work
mnt
When I launch vtune 2023.0.0 with sudo access, it gives the following error and the main window is not opened. Actually, I see a blank white page. With normal user, it is fine.
# /opt/intel/oneapi/vtune/latest/bin64/vtune-gui
[16965:0314/113223.428771:ERROR:bus.cc(398)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[16965:0314/113223.428827:ERROR:bus.cc(398)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
Authorization required, but no authorization protocol specified
[16997:0314/113223.446124:ERROR:vaapi_wrapper.cc(682)] Could not get a valid VA display
[16997:0314/113223.458666:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
[16997:0314/113223.477315:ERROR:x11_software_bitmap_presenter.cc(141)] XGetWindowAttributes failed for window 31457283
[16997:0314/113223.975054:ERROR:x11_software_bitmap_presenter.cc(141)] XGetWindowAttributes failed for window 31457290
[16965:0314/113223.990770:ERROR:cert_verify_proc_builtin.cc(690)] CertVerifyProcBuiltin for 127.0.0.1 failed:
----- Certificate i=0 (CN=optiplex) -----
ERROR: No matching issuer found
Any idea about that?
Rahila_T_Intel
Thank you for posting in Intel communities.
 I sincerely apologize for the inconvenience caused. Dev team has been consistently working on this issue.
As an alternative approach you can use the VTune GUI.
Try loading the VTune Web Server Interface by running the following command and accessing the generated URL in a browser window
$ sudo <vtune-install-dir>/bin64/vtune-backend --allow-remote-ui
Eg.: $ sudo /opt/intel/oneapi/vtune/latest/bin64/vtune-backend --allow-remote-access
The first time you access this URL on your browser, you will be shown a warning regarding self-signed certificate since the website is loaded locally, kindly confirm and bypass this warning to access the VTune Web Server GUI.
VTune Web Server Interface Documentation: https://www.intel.com/content/www/us/en/develop/documentation/vtune-help/top/launch/web-server-ui.html
Rahila_T_Intel
Rahila_T_Intel
We have not heard back from you. Could you please give an update?
mnt
Yes with web server, the sudo works fine. Thank you.
Rahila_T_Intel
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
