Analyzers
wait for appication
Douglas_R_Intel
The application I want to use Inspector on cannot be started directly; it has to be launched by another application.
Is there a way for Inspector to wait for the application to start and then start instrument.  If inspector has to launch the application directly then I won't be able to us it.
Doug Robinson
Alexandra_S_Intel
Doug,
"The application I want to use Inspector on cannot be started directly; it has to be launched by another application."
Let's call the application you want to use Inspector on Application X. Let's call the application that launches Application X by the name Application Y.
If it is possible for you to launch Application Y, then Inspector can monitor Application X as its child application. You do this by setting Inspector to run on Application Y, and set Application X as the child application.
There is no way to attach Inspector to an existing process, or to have Inspector start itself when a specific application launches.
I hope this helps.
- Alex
Alexandra_S_Intel
As I have received no response, I will assume this issue has been resolved and close the thread.
If you have a similar issue please create a new thread so we can get to you in a timely fashion.
