Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Can not find device after server carry two Arria 10 GX PAC-Reply
wgshnyhlw
Hi John,
Link to my previous question: https://community.intel.com/t5/Application-Acceleration-With/Can-not-find-device-after-server-carry-two-Arria-10-GX-PAC/m-p/1483689#M2168
I'm sorry that I opened a new subject there. I don't know why I couldn't reply to the previous subject after trying many times. I mentioned that I want to use two cards on my server at the same time before.
The output log after I use  "lspci -s 13:00.0 -v" and "lspci -s 1b:00.0" command is:
As you can see, the two cards has same device name 09c5. What do these two logs represent? Did the pci port "1b"00.0" and "13:00.0" detect two different acceleration cards?
Thanks for your support. Best wishes.
JohnT_Intel
Hi.
Both is using the same driver. It is just enumerated with different PCIe bus address as this is 2 different Physical Function.
